Small Block Build
Old Aug 16, 2005 | 05:04 PM
Ratsirt01's Avatar
Ratsirt01
Default Small Block Build
Hi there,
I am looking at putting together an engine and I was wondering if anyone could answer the following. What would I end up with using the following components;
Block part number 3970010 4 bolt mains, 327 large journal steel crank, 3927186 heads. If the above items will work what pistons would you use and what cam? The block is .60 over. What could I expect for numbers?
