'79 L48 Mods - The Next Steps??
1 - Removed the old temp controlled air cleaner and went to a 12" Edelbrock filter.
2 - Put in a Curve Sping kit into the dist and went with the black springs - the lightest ones. I don't know why. How do I determine which springs to use?
3 - Installed Dynomax Headers
4 - Changed to true duals (2.5"), no cat. with a cross pipe about 6" behind the cross member.
5 - Now, for the most disappointing, I put on Dynomax Super Turbo's. I wanted it somewhat quiet but that was too quiet. So I turned them in for their UltraFlo SS and they are just about as quiet. I talked to the guy at Flowmaster and he said it's because my L48 is just too weak and my 2.5" duals are way too big. He doesn't think Flowmaster's can help. That is disheartening news to me.
So, what's next? A carb and intake? What kind? I don't want to drag but I don't want to be Mustang bait either - HELP!
If you are just looking to make noise, why not go to glass packs, or just straight pipes with no mufflers? Also the cross pipe will change the way the exhaust sounds a bit. . .
Make it perform better? What is your budget? A relatively inexpensive upgrade would be to swap in a different cam. A more expensive route would be to drop in a whole new engine. Sorry, too vague
Oh yeah, also, what rear gears are you running? Getting steeper gears will likely make the car much more punchy if you have the same 3.08 freeway gears that I have on mine . . . Maybe some 3.73s or something . . .
As for the timing curve, Lars wrote a good tech paper on the subject. I'm still not clear on a couple of points myself, but you can read his paper and I'm sure you'll know a lot more about the subject than many do afterward. I don't recall the URL off of the top of my head, I'm sure someone else knows it though. If not, I can check my bookmarks when I get home tonight and get back to you.
-dath
specs can be seen here at gmpartsdirect.com:
http://www.gmpartsdirect.com/perform...ATID=1099.html
You can order it from Boaz Alabama at KILPATRICK CHEVROLET on 1134 HWY 431 phone number: (256) 593-4253. I think the going rate on the ZZ4 is $4,000, but there are many other options, such as getting a short block and building your own. The truth is that there's only so much that you can do with the L48 until you run into problems...it's not a high preformance engine. Oh...you can do a cam and some heads easy enough and a few tweaks to get the HP up to a decent 300 at the rear wheels, but the ZZ4 will start you at 355HP without breaking a sweat. And, if you run an L48 at 300HP for extended periods you may see some problems in the bottom end due to the fact that it's only got 2 bolts holding the main caps on while the ZZ4 has 4 bolts per cap...along with some other racing tweaks.
OK...so that's like if you have the money right?
If you are like most of us and work for a living then it sounds like you have done plenty already. Why not just buy a heck of a lot of gas and spend some time on the road? I'm a bit biased because I'm doing a front-end rebuild at the present time and am road sick vette style...think home sick and you'll see what I mean.
Do a google search on 'goodwrench series' and check out the chevy hi performance series on building up a cheapo GM crate eng which is basically a L48 eng all the way to aover 500+ in about a 8 part series that starts with low buck mods and works the eng up in steps.
-dath
Stock was 190hp.
Headers, duals, and 1000cfm mufflers???
New intake manifold???
Better Carb???
Cam???
Where would that get me?
There are so many carb's and intakes. I would like to stay EGR. What setup can I get that will allow me to stay with my stock hood?
If you want more than this you'll need more compression. When I say more compression I mean more than the head swap would give you (this means pistons and that means rebuild).
BigBlockk
Later.....
Stock was 190hp.
Better Carb???
Cam???
Carb- minimal if any over your properly working carb.
Intake- minimal about +10 at best w/ EGR. Al. intake would be a good addition at same time as:
Cam- L-48 badly needs more cam- depending on your trans., (stall if auto), rear gears- a day & night diff. can be made! Over 300 possible.
- Comp High Energy 268H
- Edelbrock performer intake (stock carb and air cleaner setup)
- Dynomax headers
- High flow cat
- Dynomax mufflers
- electric fans
- recurved distributer
I don't believe the open airfilter setup gives you any more power than the stock cool air setup. I know I could get some more fun factor if I tossed the 3.08 rear gears, but I often commute in this car and am not ready to bite the bullet for a 5-speed.
