tach doesn't work
Old Aug 17, 2005 | 04:35 PM
donm01's Avatar
donm01
Cruising
Default tach doesn't work
what steps do you follow to find out why the tach doesn't work, and if it's the printed circuit or tach it's self. thank you
Old Aug 17, 2005 | 04:54 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
We just fixed one....it had power at the back of the tach when running so we pulled it and looked at the board. It was obvious that the board was smoked - it was blackened.
..After installing the board, the tach was a little erratic so we changed the filter. All is working now....
Old Aug 17, 2005 | 07:14 PM
bams12's Avatar
bams12
Just a word of advice, if in need of a tach board ,do not buy from Ecklers . I went through the same problem with a non functonal tach. Bought new tach board, printed circuit and filter. Still no tach. It has been said that Eklers sells bad boards. Emailed them for a response and recieved none. Brent
Old Aug 17, 2005 | 07:20 PM
Avette4me's Avatar
Avette4me
Try calling them...I've found them to be decent to work with via the telephone..
Old Sep 23, 2005 | 03:46 PM
Mike Mercury's Avatar
Mike Mercury
Ecklers sells the "Wilcox" board (that's what it's being called, anyways...). And they IMO are not reliable - even when new.
Try using the board made by "Gardner"... a much better design, and a lot of care given when manufacturing it.
Old Sep 23, 2005 | 06:57 PM
Maymyvetteliveforevr's Avatar
Who sells them Mike Mercury?
To tach doesn't work
