C3 Overdrive Crossmember
Old Aug 17, 2005 | 07:32 PM
smooth-rider's Avatar
smooth-rider
Default C3 Overdrive Crossmember
Just got this today, everyone that can, send some info.
Hi Tom,
Sorry for the delay...
We've actually started the R & D phase of the C3 ('68 - '82) G-Force Crossmember.
Currently, the plan is to fit the automatic vettes with the new crossmember. The manual vettes are up in the air as the crossmember is welded in.
Any info you can provide will be helpful and appreciated.
Thanks,
John 631-325-7947
-----Original Message-----
To: Gforcgbody@aol.com
Sent: Sun, 31 Jul 2005 11:13:47 -0500
Subject: Crossmember
If you guys only made a crossmember for the c3 vettes to hook up a 200r4. All the forums I read this is the biggest problem, getting it lined up and the pipes hanging to low.
Old Aug 17, 2005 | 07:40 PM
isosceles's Avatar
isosceles
Bowtie has a tubular cross member that angles up from the center. Makes it easier to get exhaust underneath it because it doesn't have to go through holes.
Old Aug 17, 2005 | 08:16 PM
my74ls4's Avatar
my74ls4
Have a 74 coupe with a 200r4. It was a TH400. The swap couldn't be any easier. The existing crossmember lined up perfectly. I havn't seen any posts that say otherwise. As long as you have an auto already it is an easy and worthwhile swap.
Old Aug 17, 2005 | 08:20 PM
smooth-rider
Yes but I have an 81, and from the reading I will need a new crossmember anyway.
Old Aug 17, 2005 | 08:37 PM
my74ls4's Avatar
my74ls4
Will an earlier crossmember work?
Old Aug 17, 2005 | 09:59 PM
kona's Avatar
kona
I did the 200r4 swap on my 80 and you will need a different crossmember or you will have to modify your existing one. Bite the bullet and order the one Bowtie offers but be aware you still will need to play with the exhaust.
Crossmembers upto 79 will work with the 200r4.
Kona
To C3 Overdrive Crossmember
