Muncie Rebuild Help
Old Aug 19, 2005 | 01:00 PM
Dick72LT1's Avatar
Dick72LT1
Default Muncie Rebuild Help
This is the first time I've taken apart a Muncie and I'm encountering a few problems that I need help with. I bought a rebuild kit and a video. The guy in the video makes it look easy - it literally falls apart by itself. Meanwhile back in my shop I have two problems:First, the main bearing seems to be stuck onto the main gear assembly. The video shows it coming off the input shaft with the help of a screwdriver or two. My bearing moves a little, but will not exit the housing because of the main gear. How much persuasion should I use and where?
Second, the counter shaft seems stuck. I got it to move a little (1/8") with some pounding, but again, I'm comcerned about how much force to apply. Any suggestions?
Old Aug 19, 2005 | 02:42 PM
GTR1999's Avatar
GTR1999
Ok basic question, are you sure you have a Muncie? Sounds like a ST-10, the front bearing is a bugger and there is a woodruff key in the countershaft end on those. Muncie front bearings are a looser fit and should come out without a lot of effort. If you have the video that Paul from 5 speeds sells it's a pretty good one.
Gary
Old Aug 19, 2005 | 03:50 PM
Dick72LT1's Avatar
Dick72LT1
Yep, It's a Muncie. The video is 5Speeds and their bearing sure is looser than mine. I'm reluctant to pry too much for fear of dinging the aluminum case. I'm soaking it with penetrating oil in the event it's corroded. I've banged on the shaft a bit, but again, not too much yet.
Dick
Old Aug 19, 2005 | 06:57 PM
Larry3x2's Avatar
Larry3x2
I've always wound up using a guillotine bearing puller and a hydraulic press.
Larry
Old Aug 20, 2005 | 04:54 AM
Rockn-Roll's Avatar
Rockn-Roll
Are you talking about the rear bearing:
or the front one?
Did you remove the retaining ring from around the main bearing? It's been awhile, but isn't the bearing pressed onto the shaft? However, the bearing should slide in and out of the housing with ease...as long as you remove the ring from the outside rim of the bearing.
The counter shaft has a hollow tube full of bearings running down the middle of it which has a rod pressed inside it which needs to be pulled out before the shaft itself will come out. The shaft is shimmed on each end, and that center tube tends to catch on the shims. In fact, if you can get in there with a screwdriver and poke one of the shims out and pull it out with some pliers then the countershaft will come out a lot easier.
Old Aug 20, 2005 | 09:19 AM
Dick72LT1's Avatar
Dick72LT1
Thanks, RnR. I'm talking about the main drive bearing - the front bearing. Yes, I took the retainer off. That keeps the bearing from going into the casing and shouldn't affect its removal outward.
It looks like the bearing and the shaft got married some way (corrision). I haven't tried the big hammer yet. No time last night, but still soaking with penetrating oil.
Dick
Old Aug 20, 2005 | 09:34 AM
GTR1999's Avatar
GTR1999
Maybe someone used some Loctite on it in the past? Try using a propane torch around it, if there is loctite there that should loosen the bond.
Gary
Old Aug 21, 2005 | 11:54 PM
5speeds's Avatar
5speeds
Default an alternative to the step in the video.
With the gear train removed from the case, leave the input shaft in the case with the outer snap ring on the front bearing. DO NOT bang on the end of the input shaft. Use something such as n old wrist pin to go around the input pilot area and either press it off on a press or use a hammer.
Paul - the guy in the video...
You can hit the countershafts pretty hard with a drift pin. You may have to press that out as well.
Old Aug 22, 2005 | 11:56 AM
Dick72LT1's Avatar
Dick72LT1
Thanks, Paul. You made it looks so easy I was afraid to apply too much pressure. I'll take it up a notch before I look for professional help. I'm limited in my tool selection.
Dick
To Muncie Rebuild Help
