fresh air door
Old Aug 19, 2005 | 03:19 PM
gator79's Avatar
gator79
Default fresh air door
for those of you that have sealed off your fresh air door in the cowl area, how did you do it? my vac motor is still good and holds it open, it closes most of the way in max a/c. did you disconect the motor from the door? and what did you do to keep it closed? there is way to much heat getting in from there.
Old Aug 19, 2005 | 05:05 PM
BerniesVette's Avatar
BerniesVette
I'm sure there are better ways of doing it, but I used duct tape as a quick fix to keep the door closed. I can remove the tape in the fall for fresh air if I want too.
Bernie
Old Aug 20, 2005 | 10:50 AM
terry82's Avatar
terry82
i replaced the seal .no more hot air .but if you dont need it ,duct tape would work.
To fresh air door
