Running hot
Old Aug 20, 2005 | 01:14 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Running hot
MY car runs hot when you start it let it warm up it takes it a couple of minutes then its at about 150 the when you drive It takes about 5 mins or so to get to 180 which is the thermostat I have installed. After about 20 mins of driving around town at about 30-50 miles an hour it gets about 210 and sometimes goes all the way to 250. I have autometer sport comp guage in the car and it is wired in to the factory unit. The radiator is a new aftermarke factory stlye with a 12 and 10 inch electric fan. Water pump is flowing good and all should be well. So my question is why does it run hot. Also it is not overheating just running hot to extreamly hot.
Old Aug 20, 2005 | 02:21 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Do you know that your original water sensor is accurate?
Old Aug 20, 2005 | 02:25 PM
Silver00V6Camaro
no i do not know if it is
Old Aug 20, 2005 | 03:39 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
still got the one that came with the gauge that you can run a temp wire too and check it with that?
Old Aug 20, 2005 | 05:35 PM
Silver00V6Camaro
Yea I still got the one from autometer as soon as the car cools down I plan on putting it in. How hard is it to put one in.
Old Aug 20, 2005 | 05:57 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
since the gauge is hooked up, I would just put the sensor in one of the ports on the intake, and run a temp 18 gauge wire back to the cab and hook it to the sensor connection on the gauge and then go for a drive and see if it is the sensor. If not, just pull the autometer sensor out and hook up the old one again.
Old Aug 20, 2005 | 09:56 PM
Swave Dave's Avatar
Swave Dave
This is where an infra-red thermometer would come in useful ; point it and shoot to get your reading. You may not be overheating at all -- could be a bad guage or sensor . In the event you are ACTUALLY overheating as stated, investigate these things :
Are radiator sides/top/bottom sealed up ? Is the lower radiator hose collapsing at 3000 rpm thereby restricting flow ? Is the radiator/condensor surfaces clean ? Is the fan belt slipping at higher rpms ? DId you thoroughly clean the cooling system ? Are you running no more than 25% coolant to water ratio (water is the best cooling medium) .? Is the new thermostat sticking ? Temporarily take out the thermostat and go for a long spin --- see if anything changes . Good luck. Dave
Old Aug 20, 2005 | 11:08 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
some good points Dave!
:CHEERS:
Dave <---also
To Running hot
