Re-curve kit part number needed
Old Aug 20, 2005 | 08:40 PM
desi's Avatar
desi
Default Re-curve kit part number needed
Checked my timing today:
initial was 27, total with mech (vaccum disconnected) was 37.
Took the bushing (under the weights) out to see whether there is any difference. Got 17 initial, 27 total
It's a 74 distributor with Crane XRi conversion kit. I am going to play with weights and springs until I get 15 - 18 initial, 36 total.
What kits are out there? Make and part number would be appreciated
Old Aug 20, 2005 | 08:50 PM
goinbroke's Avatar
goinbroke
You will probably be looking at the 928G. http://www.jegs.com/cgi-bin/ncommerc...32&prmenbr=361
Check your local auto parts store. Mine had most all the GM recurve kits.....Mr.Gasket brand.
I'm mainly curious to know how you like the new Crane XRi system. I currently have the old XR700 set-up and have thought about going to the XRi.
Old Aug 20, 2005 | 09:01 PM
desi's Avatar
desi
Thanks for the link. I was looking at -926G because I need weights as well. But the kit only has one set of springs??
XRi unit is good. Easy to install. Smoother idle.
Old Aug 20, 2005 | 09:06 PM
desi's Avatar
desi
Anyone use Accel ACC-31042 kit?
Old Aug 21, 2005 | 11:07 AM
PRNDL's Avatar
PRNDL
interesting that they have a pre 69 kit and a 69 and later kit. I have a 68, although I am not sure if my distributor is an actual 68 distributor. I am not sure which kit I got (This isn't very helpful or descriptive, is it? ) My point is, the weights in the kit I got did not fit. I wonder if that is the difference between 68 and 69 ?
Old Aug 22, 2005 | 12:00 PM
desi's Avatar
desi
Just ordered the Morroso MOR72310. Should work well.
Old Aug 22, 2005 | 03:14 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
929G has 3 sets of springs, just installed it.
To Re-curve kit part number needed
