Did I jump time?
Timing chain slip or am I missing something?
Not likely that it jumped time but what does happen is that the oil pump drive shaft is having a difficult time lining up with the bottom of the distributor drive shaft.
You could get a long screwdriver and turn the oil pump drive shaft a bit to make it easy to align with the distributor shaft. Keep in mind that the disributor shaft will rotate as the gears mesh on the way down. If you miss by a tooth you can always rotate it out and turn it a little bit more. If the bottom of the disributor is not flush with the intake manifold, then the oil pump drive is not engaged and it is preventing the distributor from dropping all the way down.
-Mark.
-Mark.
I just got back in from turning the drive a little. Worked perfectly.
I sincerely appreciate your help...
Lonny
