HELP! lights stopped working.
Old Aug 21, 2005 | 12:22 PM
Tom68's Avatar
Tom68
Default HELP! lights stopped working.
Started to town the other evening pulled on the lights only tail lights and markers working. Looked at fuse block changed tail light fuse. Now none of them work. Installed new light switch the low beams only work. No dash, park, tail lights. And you push the high beams and they don't come on either. I jumpered from the hot wire to different connections in the switch plug and all the lights will come on one at time. They just don't work from the switch. This is driving me crazy. Oh I did ground the switch while doing the trouble shooting. Any Ideas?
Thanks Tom
Old Aug 21, 2005 | 12:46 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
look for corrosion on the fuse panel.. mine did that and it worked fine after i sprayed it down with terminal cleaner...
Old Aug 21, 2005 | 08:57 PM
Tom68's Avatar
Tom68
I did the contact cleaner and no help. Any other Ideas? What could have caused this?
Old Aug 21, 2005 | 09:32 PM
Tom68's Avatar
Tom68
Default Problem found Thanks Aflac
Went back out and worked some more on cleaning the fuse block contact. That was the problem RUST.
Thanks Guys
Old Aug 21, 2005 | 09:34 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
no problem man.. if my little bit of what i have learned can help someone else, i'm all about sharin it!
To HELP! lights stopped working.
