lower air dam
Old Aug 21, 2005 | 12:50 PM
gator79's Avatar
gator79
Default lower air dam
the lower rubber air deflectors on my 81 are missing, how much will this help the engine cooling if I put new ones on. it is running about 230 on the highway with a/c on, 220 wiithout a/c.
Old Aug 21, 2005 | 12:52 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
You will notice a temp drop. I would replace the air dam as soon as you can. Atleast a stock one.
Old Aug 21, 2005 | 01:19 PM
Empatho's Avatar
Empatho
the air dam helps on highway driving
Old Aug 21, 2005 | 01:25 PM
fugawi's Avatar
fugawi
get one. it helps mucho grande
Old Aug 21, 2005 | 04:32 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I used to run those type of temps with the lower dam on my '80. Finally looked at the ragiator and it looked like the arteries of a 90 year old cheese eating chyampion....clogged
Got a radiator from corvette central (about $250) and a new foam kit from Doc rebuild (about $50) and with a 180 thermostat, I run about 180-200 on 95 degree days here...
Old Aug 21, 2005 | 04:36 PM
gator79's Avatar
gator79
I have a new radiator and fan clutch. also thinking about electric fans
Old Aug 21, 2005 | 04:38 PM
Avette4me's Avatar
Avette4me
how's the foam around the radiator and on top of the rad support?.....
Old Aug 21, 2005 | 07:37 PM
gator79's Avatar
gator79
that part is sealed good, my temp probe is in my thermostat housing, some say that it is hotter there than in the heads, I am not running a thermostat, removing it may no difference in temps
Old Aug 21, 2005 | 08:59 PM
Rockn-Roll's Avatar
Rockn-Roll
Right...so your bottleneck is not coolant flow. The only other bottleneck would be air flow. Get the air dam before you melt something. And, as others indicated...seal up the front area of the radiator so that all of the air scooped up by the air dam will flow through the radiator.
Old Aug 22, 2005 | 12:40 AM
flynhi's Avatar
flynhi
A few years back Bubba replaced my fan clutch and reinstalled my metal fan backwards. I ran hot until I figured this out....
Old Aug 22, 2005 | 12:42 AM
CrossedFlags77's Avatar
CrossedFlags77
Definetly install a new front air dam if you are missing yours. Corvettes are bottom feeders when it comes to cooling. I would also hold off on the electric fans until you figure out your cooling problems.
Old Aug 22, 2005 | 05:05 AM
Bangkok Dean's Avatar
Bangkok Dean
Yes dam that air
Old Aug 22, 2005 | 10:43 AM
lvrpool32's Avatar
lvrpool32
When I put my fabricated spoiler on I was amazed by the difference.
It has been in the 90's and humid round here recently and my car has been on two recent 25mile + trips to shows and the car has barely gotten over the first mark on the temp gauge.
Nick
Old Aug 22, 2005 | 11:02 AM
Twin_Turbo's Avatar
Twin_Turbo
nick, that car of yours is getting slicker by the day, I love the new wheels, the lights and the air dam, looks like a race car
Old Aug 22, 2005 | 11:48 AM
71redskin's Avatar
71redskin
thats pretty slick nick... what did you make you air dam with...like to do the same to my 71 BB
Old Aug 22, 2005 | 07:34 PM
DaveL82's Avatar
DaveL82
My 80 has the same front end and I haven't had the lower pieces on for years.
The biggest issue with ours is a good radiator. I replaced mine and it was much better on the highway but 200 to 210 with AC and driving slow in traffic. I finally replaced all seals around the radiator and made sure that when the hood closes there is a seal with pieces of foam. Now car has been 180 for last 6 years. You would not believ ehow important it is to seal every hole or the fan will not suck through the radiator.
Dave
Old Aug 22, 2005 | 08:14 PM
ETM's Avatar
ETM
I had the same problem on the freeway when I first bought my Vette.The air dam made a world of difference.It should run cooler on the freeway and now it does.
Old Aug 22, 2005 | 10:02 PM
Taijutsu's Avatar
Taijutsu
My 74 had the crappy 3 core rad. I had it rebuilt w/4 core and had a petcock added for easier draining. No contest. Before that I tried oil cooler helped 5o, eliminating the fan clutch to run 100% 7 blade fan and the 1.6 rrs made a big difference. The stk 3 core is not up to running w/A/C. After the 4 core rebuild, I added dual spals. In a traffic jam a C5 driver asked my temps 190, his were 230. He was stressed!
Rick
PS. Adding the extra core during rebuild was very cheap!
Ask your local rad man.
To lower air dam
