reamer help + front steer stuff
Old Aug 24, 2005 | 03:41 PM
Twin_Turbo's Avatar
Twin_Turbo
An arch is best in taking loads pointing from the top to bottom, spreading the load out through it's legs, arches are not very good at sideways loads where a triangle is
Old Aug 25, 2005 | 01:54 PM
housegarage's Avatar
housegarage
The taper is 1.500 inch per 12 inch - 8:1 taper. The small end of the taper should measure .516 and the straight shank at the large end of the taper measures .626. This is for Moog version of the tie rod end ES323.
Old Aug 25, 2005 | 04:59 PM
Techno's Avatar
Techno
I get it now.
Thanks for clarifying that.
Old Aug 25, 2005 | 05:07 PM
Fevre's Avatar
Fevre
Thanks for the physics lesson TT.
Old Aug 26, 2005 | 03:10 AM
Twin_Turbo's Avatar
Twin_Turbo
cool 1.5"/ft ...just what I needed. So no one has that reamer? Damn..there goes another 100$.
Old Aug 26, 2005 | 04:25 AM
72 RAY's Avatar
72 RAY
Hey TT,
Most tire and suspension shops have those in their arsenal. I once borrowed one from my local guy to fix a buggered one on my truck. Try that before you shell out the bucks.
Those a-arms look like the pole position ones I got for my car they work great.
Good luck!
Old Aug 26, 2005 | 12:27 PM
Twin_Turbo's Avatar
Twin_Turbo
Yes, but I'm over here on the other side of the pond where there are no shops, no tinkerers..no nothing so no one will have it. The arms are pole position indeed.
Old Aug 26, 2005 | 07:02 PM
Techno's Avatar
Techno
I saw a way to make a reamer for home use. A length of drill rod was cut at an angle.
Looking at it on the side, slice from near the middle at the top down the side at an angle. About 2" down for a 1/2" or so rod. The angle isn't critical. Just a big wedge taken off.
I don't see any reason you can't machine a taper and take that wedge shape out of it for the cutting surface. You would only need to know where the large end needs to stop. This is a hand use only tool with limited uses. Sounds like about what you need?
Of course it isn't going to cut a taper only ream one already made.
Now that I think about it the wedge would have to stop at the large end.
If you do try it might do a test run since the straight one seems to be piloted not sure on the tapered surface.
Old Aug 26, 2005 | 07:05 PM
norvalwilhelm's Avatar
norvalwilhelm
Send the parts to me and I will ream them for you. I can not send the reamer out. It needs to stay close to home for others to use.
Sorry
Old Aug 27, 2005 | 07:25 AM
Twin_Turbo's Avatar
Twin_Turbo
I need to do a little reaming on my spindles also...I'll just buy my own thanks for the offer...if it was just the steering arms I'd send them your way immediately
