Cam Lobe Wiped
Old Aug 22, 2005 | 02:37 PM
wes77's Avatar
wes77
Default Cam Lobe Wiped
I installed a xe-262 Comp Cam in my 77 vette around 4 years ago. I haven't put on a great deal of mileage and now #7exh lope is wiped. Has anyone had a problem with Comp Cams? What new cam would you recommend. It'a a 77 L-48 with performer intake and QJ, 4 speed. When I installed it, I bought the kit: cam, lifters and springs. The engine ran smooth until the lope wiped.
Old Aug 22, 2005 | 04:41 PM
GTR1999's Avatar
GTR1999
You have joined the XE club!
http://forums.corvetteforum.com/show....php?t=1150869
Gary
Old Aug 22, 2005 | 05:36 PM
desi's Avatar
desi
What are signs of a wiped lobe cam? Is it obvious to detect?
I installed one about 500 miles ago, and it runs like crap.
Old Aug 22, 2005 | 06:26 PM
79VetteMike's Avatar
79VetteMike
the signs are that the part number begins with XE....
Old Aug 22, 2005 | 07:26 PM
Retro78's Avatar
Retro78
been a ton of these lately.
Old Aug 22, 2005 | 09:18 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if you pull the valve covers and the rocker arms aren't going up and down you have a problem.
Old Aug 22, 2005 | 09:31 PM
wes77's Avatar
wes77
The engine was popping through the carb and #7 exhaust rocker arm was not opening and closing
Old Aug 22, 2005 | 09:44 PM
bobs77vet's Avatar
bobs77vet
and adjusting it does nothing right? ......well that sure sounds like a wiped lobe...
Old Aug 22, 2005 | 10:08 PM
gator79's Avatar
gator79
you usually start to get this popping in the carb on acell, once you hear it you get this sick feeling and you know its not gonna be good
Old Aug 22, 2005 | 11:09 PM
Kid Vette's Avatar
Kid Vette
That made the old sphincter tighten up! I just installed the exact same cam this past spring! I've been drivin' it all summer. So far so good....
Old Aug 22, 2005 | 11:30 PM
steves_77vette's Avatar
steves_77vette
I can't speak more than this experience so far:
* XE268H wiped during break-in #8 exh, first 30 minutes of run time and yes, I followed the procedure
* Worked with Summit and they replaced it with a Lunati with no trouble
* I would be able to tell you how it went except an electrical problem popped up and I couldn't start the car, hope to tomorrow now that I found that and will report on the results
I just lost all confidence in Comp right now. If you have a cam and are good, you're probably ok. But they seem to have quality control issues with the match between cam and lifter IMHO. Somone mentioned crown spec issues a couple weeks back and that sounds believable to me.
Old Aug 22, 2005 | 11:51 PM
mandm1200's Avatar
mandm1200
I'm glad you said it and not me! From what I know about and heard about these cams there is a risk in using them. Let me rephrase that. I have no experience with them but have heard plenty of the wiped lobe threads. The cam is highly aggressive in the ramp. Most people do not have a problem with them. Some may not break them in properly and others may have other issues that lead to premature wear. When things go all right, one could expect to get a few more ponies versus a more conventional cam with less aggressive ramps. There was a recent poll on the forum and the results were in my opinion not the good. Using one of these performance cams is taking a higher risk. That does not mean everyone will fail, nor does it mean that a majority will fail. It means that cam failure will occurr more frequently than most other cams.
Old Aug 23, 2005 | 02:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
Aggressive ramps never seem to last too long on street cams for some reason. I suffered a few broken dampners too after 300 miles(yes, the springs were set up right). That's unacceptable IMO-Comp 284 XE
Old Aug 23, 2005 | 02:07 PM
stingr69's Avatar
stingr69
But nobody seems to be worried untill after the lobes get round. OH WELL!
-Mark.
Old Aug 23, 2005 | 02:53 PM
steves_77vette
All the Biggies have an aggressive cam line but you don't hear about Crane, Lunati, Isky failures. Either no one buys them or Comp has a specific problem. Also, reading the latest article from Vizard in Popular Hot Rodding and he mentioned about testing some hydraulic roller cams back in the early '90s and the fact the results were poor so they did NOT write the article. That disappointed me to read that. In other words, they write the good news and nothing on the bad. That's not journalism, that's called being a shill.
Old Aug 23, 2005 | 03:16 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
add me to that list.. my xe 268 had a cam lobe starting to go at 1500 miles.
Old Aug 23, 2005 | 03:43 PM
1978SA's Avatar
1978SA
A shout in the distance says... "go roller my man...go roller..."
Money is definitely an issue to convert though, but what a piece of mind.
To Cam Lobe Wiped
Old Aug 23, 2005 | 04:19 PM
evil herbavore's Avatar
evil herbavore
Going roller just becuase flat tappet cams are having probs is silly.
Old Aug 23, 2005 | 04:39 PM
1978SA's Avatar
1978SA
I guess your humor button is turned off.
BTW, roller does allow quicker ramps, better torque cures, etc, all with a "small" profile that aids in drivability through out the RPM range.
Besides, it's just cool to say.."I have a roller cam in there"
Old Aug 23, 2005 | 07:21 PM
JPhil's Avatar
JPhil
Well that does it. The XE262 on the bench sho nuff AIN'T goin' in my car. I'll go back and find yet another one.....
Anybody wanna buy a still-in-the-box XE cam? I'll make you a good deal! (No, I couldn't sell it to anyone here: first, nobody here would buy it anyway, but I wouldn't be able to show my face here anymore either. Guess I'll throw it out in the back yard, let the roses grow on it and call it a "sculpture.")
John
