problems with heater core
Old Aug 24, 2005 | 08:04 PM
a smith's Avatar
a smith
Default problems with heater core
1976 Stringray. I have had to replace the heater core about every two years.What I am finding is the body of the core,on both sides, is expanding outward and ripping open. Anyone here having the same problem? Also having problems with PS pump. I cannot get a good seal with the housing to the pump. Seems to be leaking around the o-ring area? Anybody having the same problem? Solutions? Thanks, Al.
Old Aug 25, 2005 | 01:07 AM
chris75stingray's Avatar
chris75stingray
is the heater core expanding from pressure inside it?
are you buying the same heater core each time? they might be made defective
never heard of a heater core doing that
Old Aug 25, 2005 | 01:14 AM
45ACP's Avatar
45ACP
Any chance that you are freezing up? If you get lows temps and your coolant is not up to the task....
Old Aug 25, 2005 | 08:38 AM
pws69's Avatar
pws69
Things that come to mind:
What is the Radiator Cap pressure rating? Have you replaced it recently?
Is there a valve in the heater hose? If yes, which hose (supply or return)?
To problems with heater core
