So my questions are...the strut rod kit says it comes with instructions...but does not. Anything that's not obvious I should know about them before installing?
What else is HIGHLY recommended when doing the rear end? What other parts are must haves?
Since the trailing arms have been done the struts should come off without much trouble. I couldn't get mine off until I got the t. arms off. Sounds like you have everything you need. Good luck!
Bernie
