C3 rear wheel backspacing?
Should I assume I'll need to use notched control arms and massage some of the inner fenderwell? Any other pitfalls?
Thanks for the advive,
Dave
Nearly every good working NHRA/IHRA stock eliminator car I've seen lately has been running 10" rims with the above tire combo. Just trying to see if anyone on the forum has gotten this package to fit.
Dave
#1 to much rear squat. To correct the problem I installed Smart struts and Zero toe on my HD trailing arms with good shocks sway bar and 420 inch pound steel custom spring.
#2 Now it got rid of rear squat, but you don't have the weight transfer. Your even taller 30 inch slicks - which lift the rear end because of tire diameter will cause additional problems. So I had a car that as I had motors with more power I had rear hook up problems. My solution was to severly lighten the front end. I went to extreeme levels of even the Datona nose just to loose another 150 pounds by having such thin fiberglass hood and body panels.
For drag racing you really need to to look at 90/10 drag shocks, lite long springs with drag skinnies. I even considered the battery box relocated behind the passenger rear tire.
In the end I figured out that running a Drag bike was much more adrenilan (SP?) and much cheaper on parts.
Without a doubt. Just get on a 7.60 turbo lay down drag bike with an air shifter. Then don't even wait for the shift light to come on and just keep it hammer down. Your on the wheely bars to just under the 660 foot light. Cars are very boring and way to safe!
I have an article on Vette 17" and 18" wheels and they did a bunch of testing and the MOST Backspace they could get on a 17" wheel with 285 40 17 wheels was 5". This with offset trailing arms. Don't think they had a shortened spring and they said this combo would run on the rear sway bar.
Personally, I wish I had gone with double offset trailing arms and the heavy duty halfshaft/spindel kit from Vansteel, but it is expensive.
I am certain that you could NOT run 5" bs wheels with 15 X 10 rims with stock trailing arms, so don't even try. I think 4.5" bs is the most you could go.
The spring eliminated all squatting.. I don't get more than 1/2 inch travel in the rear...
I use 28 x 13.5 - 15 ET Street tires (11 inch tread) on 15 x 10 Convo Pro wheels.. In front, I use '65 Corvette Small block springs and Competition Engineering adjustable Drag Shocks (set to 80/20).
On a well prepped track, I don't have traction issues with my setup, however, my front bounces.. (wheels come off the ground by about 2 - 3 inches, then come down and then they come off the ground again by about 2 inches... Other than the bounce, the suspension works great!
As I told you in the PM, in order for the rear tires to fit, I had to
1) remove the rear sway bar
2) use the narrowed rear spring
3) cut a small piece of the frame (where it comes down to the trailing arm
This C3 project was back burner but it's warming up fast. I picked up a lot of missing parts lately so now I've got the itch to start putting it together. Are you automatic guys running TH400s or 350s? I'd prefer a 350 if it's not to much of a PITA to swap in.
I'm in need of a lot of the grill/front end mounting hardware, if anyone knows of a stash out behind a garage or barn for cheap please let me know.
Keep 'em racin',
Dave
Keep 'em racin',
Dave
When ever you use a "A" tranny You might talk about 25-50 hp in comparision to full man stick shift. 400's can take on 1200 hp
I used power glides in a dragster.
The real key like my 850 hp Art Carr tranny is such grade high steel make them last a long time.
My wimpy motor never hurts it.
