Rectangular or Oval?
Old Sep 1, 2005 | 08:48 PM
Mllrvette1968's Avatar
Mllrvette1968
Default Rectangular or Oval?
How can I tell the difference between oval port and rectangular port heads? What is the diff. in power, and what do they do differently?
Old Sep 1, 2005 | 09:15 PM
pauvil's Avatar
pauvil
Your talking big block, oval ports are "oval" and rectangular are more square, generaly rectagular ports flow better above 5500 rpm if your talking stock iron heads, any aftermarket head tends to flow better because of better combustion chamber design. When it comes to stock heads the 781 oval castings will flow just as good as any stock rectangular head up to 5500 rpm, if you are on a budget get the "vortecs" . All depends on what your trying to do and how much money you have.
Old Sep 1, 2005 | 09:24 PM
Mllrvette1968
Old Sep 1, 2005 | 09:53 PM
62fuelie's Avatar
62fuelie
Typically, when considering stock heads, the oval ports are superior for the street, and the larger rectangular heads are superior for high RPM applications. You typically "drive torque" and "buy horsepower". You need to decide what your goal is.
Old Sep 1, 2005 | 10:12 PM
Corey_68's Avatar
Corey_68
This thread might help.
http://forums.corvetteforum.com/show...gle&forum_id=3
Old Sep 1, 2005 | 10:56 PM
Todd68's Avatar
Todd68
Default Here's some pictures that may be useful:
Oval port heads:
Rectangular port heads:
Here's an article about heads with flowbench data for small & big block heads, both factory & aftermarket. Scroll down to bottom of page for links to "sidebar articles" to see flow data for various heads.
Flowbench database
Hope this helps!
To Rectangular or Oval?
