Trailing arm questions
Old Sep 2, 2005 | 02:36 AM
White 68's Avatar
White 68
Default Trailing arm questions
Could one of you check the measurements on your trailing arms against
the pair listed here in the pictures. They seem a bit short. They are build stout and nice , but came off a hot rod running a corvette rear end . If they don,t measure out right they,ll be back on ebay as they are really quality arms. Thanks
Old Sep 2, 2005 | 03:35 AM
jyounane's Avatar
jyounane
Default Too short
Way too short....I measure around 17" to 17 1/2" between the spindle center (center of the bearing carrier hole) to the center of the bushing.
You picture shows around 14"
Cheers Joe
