still getting run on
Old Sep 2, 2005 | 01:25 PM
madvette74's Avatar
madvette74
Default still getting run on
A while back I started a thread on this problem of mine, I thought it may have been a return spring. I changed the spring lowered my idle to about 750-800 it still likes to run on after I shut the car off, I checked the float level in the primaries it was fine, however the secondaries float level seems to high, when I take the plug the fuel dribbles out, I cant lower the float. I believe you loosen the nut and turn the screw clockwise to lower but it's all the way in. and still dribbles out.. could this be a problem for run on?
Old Sep 2, 2005 | 01:28 PM
lars's Avatar
lars
No.
Run on is caused by excessive idle speed at shutdown. GM had this same problem and solved it by installing the anti-dieseling solenoids used in the mid-70s. If you cannot solve the problem by lowering idle speed, you may consider installing an idle solenoid to close the throttle blades after engine shutoff.
Old Sep 2, 2005 | 01:38 PM
not a '76's Avatar
not a '76
msd ignitions can cause run on too.
you gotta throw a diode somewhere to fix it.
Old Sep 2, 2005 | 03:13 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
just out of curiousity, what octane are you running for gas? if you are running 87, step up a grade and see what happens
Old Sep 2, 2005 | 03:25 PM
lars's Avatar
lars
That's correct. The MSD instruction sheet has a diagram showing the required modification to eliminate run-on caused by MSD.
Old Sep 2, 2005 | 03:26 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
isn't retarded timimg also a cause of run on?
Old Sep 2, 2005 | 03:28 PM
lars's Avatar
lars
It can be, since retarded timing will require that the throttle blades be opened more to maintain idle speed. The open throttle blades can induce run-on.
Old Sep 2, 2005 | 07:09 PM
Sharky Guam's Avatar
Sharky Guam
Are you running aftermarket electric fans?
Old Sep 2, 2005 | 10:53 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Originally Posted by lars
No.
Old Sep 2, 2005 | 11:44 PM
madvette74's Avatar
madvette74
thanks for all the replys.. again I tried lowering the idle, it's now hovers between 700-750 rpm, I no longer have run on.. finally. but I do have an electric fan, not in use. I run at 190 degrees.. but I would like to know about the diode for the msd ignition, because I have that and knew nothing about a diode or where it goe's.. could someone here send me some directions on this?
Old Sep 3, 2005 | 01:23 AM
comp's Avatar
comp
didn't know this one
Old Sep 4, 2005 | 06:20 PM
madvette74's Avatar
madvette74
well I spoke to soon, I now have my car idle at 600 cant believe I can get it that low.. here's is something I over looked. when I first took my car out this year, I noticed on several occasion that my fuel pressure was over 9psi what reminded me was, when I was driving today and noticed it at 15psi.. I usually shut the pimp off and turn it back on and it fixes it self.. I have the holley blue pump with regulater.. could I have done something to the carb that now makes it leak, so when I shut it off I get the run on? also still could use that info on the diode with the msd..
Old Sep 4, 2005 | 06:49 PM
not a '76's Avatar
not a '76
the diode instructions are in the papers your MSD box came with.
like the 6a instalation guide.
it amouts to a diode in line with a wire coming off the alternator.
the msd website probably has the instructions somewhere.
To still getting run on
