gas leak
Old Sep 4, 2005 | 12:39 AM
logansrun73's Avatar
logansrun73
St. Jude Donor '14
Default gas leak
How fast does the gas run on my arm when I change the rubber gas line between the hard line and the fuel pump? Also the best way to eliminate to much g as waste. Now a days every drop counts!!!!!!!!!!
Old Sep 5, 2005 | 11:37 PM
logansrun73
St. Jude Donor '14
ttt
Old Sep 6, 2005 | 09:45 AM
KenSny's Avatar
KenSny
Your probably not getting any answer since the answer should be obvious! Drain the tank BEFORE you work on the lines, not AS you work on the lines. Think SAFETY FIRST. It's very easy to siphon the gas out thru the filler before you disconnect a line. Then drain what's left. NEVER have gas running on you as you work. A spark will set off the fumes or even your trouble light will set it off.
Old Sep 6, 2005 | 10:00 AM
big_G's Avatar
big_G
And PLEASE have a fire extinguisher next to you when you are working with gasoline. Y'all have an ABC rated fire extinguisher in your garage, don't you?
Old Sep 6, 2005 | 10:51 AM
rponfick's Avatar
rponfick
First, get an assortment of those rubber caps like used to cap various size vacuum fittings, I think 3/8" is the usual size. Quickly pull the hose off the hard line and slide a cap over it. Then you have all day to remove the old line and hook up the new hose to the fuel pump. When all connections are done down below, just quickly remove the cap and slide the new hose over the hard line.
To gas leak
