BB Spring Rates
Old Sep 6, 2005 | 11:26 AM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Default BB Spring Rates
Any idea's where I can find out what the stock sring rates are for a 1972 BB coupe, manual trans, no air.
On another note, the shocks on my coupe are too soft for my tastes, thinking about Bilstein or Koni, any opinions?
Thanks!
Old Sep 6, 2005 | 01:27 PM
henny496's Avatar
henny496
Default spring rates
Hello
I am not 100% sure on this, but I thought SB cars were 450 lbs/in and BB cars were 550 lbs/in
take care
Tom
Old Sep 6, 2005 | 01:37 PM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by henny496
Hello
take care
Tom
Stock small block cars were only 280 pounds. I ran these small block springs with my bigblock and blower combination and really liked them. Big blocks are around 330 pounds and that is just a wild guess.
Old Sep 6, 2005 | 04:08 PM
Tom454's Avatar
Tom454
Thanks!
Front or Rear?
Old Sep 6, 2005 | 04:12 PM
norvalwilhelm
Production front was 280 pounds and 140 back. The F41 front was 550 and rear 305
Daytona fronts were available at 860 front and 450 back.
This is from the Chevy Power 4th edition.
Old Sep 6, 2005 | 05:17 PM
Wrencher's Avatar
Wrencher
I have the F-41 on mine, and even with the weight of a all-iron 427 and A/C, it's miserable on rough roads or streets. However on smooth pavement it's awesome, as long as you watch for uneven surfaces where it tends to move around a bit under you, and takes some getting used to! A bit more compliance (or much stickier tires) in the front would be perfect.
Hans
Old Sep 6, 2005 | 09:18 PM
danthony's Avatar
danthony
Originally Posted by Tom454
Front or Rear?
Both would be nice. I believe that the rear was 360 stock though.
Old Sep 7, 2005 | 11:24 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Default Spring Rates
"danthony",
The following list of spring rates is correct for the 1968-1972 model years (there may be carry over into later years, but I am unsure of particular applications):
FRONT SPRINGS
327/350 (no A/C) - Part #3931823 - "HS" - 250 lbs/in
327/350 (with A/C) - Part #3931824 - "HT" - 264 lbs/in
427/454 (no A/C) - Part #3931825 - "HU" - 284 lbs/in
427/454 (with A/C) - Part #3931826 - "HV" - 325 lbs/in
F41 (all) - Part #3832518 - "EA" - 550 lbs/in
REAR SPRINGS
327/350/427/454 (except F41) - Part #3850839 - "EA" - 70 lbs/in (per side)
F41 (all) - Part #3828811 - "EB" - 152 lbs/in (per side)
The springs were actually chosen based on sprung curb weight, but it usually took the addition of air conditioning to require a change to the higher rate spring (which is why I listed it as "with a/c").
So, to answer your question as to what springs came on your 1972 LS-5 Corvette... "HU" (284lbs/in) front springs and "EA" (70 lbs/in per side [140 lbs/in total]) rear springs.
As for shock absorbers... Koni and Bilstein are fine choices. If you can find a set of Delco Reactec shocks you'd probably be just as happy and spend a heck of a lot less too.
Regards,
To BB Spring Rates
