Question about timing
I finally got around to working on my 1972 SB with AT. I was going to check the timing and found that the vacuum advance hose was not connected to any vacuum source at all. I think that it went to the TCS solenoid, which was plugged at the output. The vacuum port on the carb. was also blocked off, which should mean that I did not have any vac. advance on the car.
I started checking the dwell, rpm and timing. I am asking if this is a normal situation.
1. With the vac. advance hose disconnected and blocked, my starting point was:
dwell 35 degrees
rpm 800 rpm
timing >16 degrees * my guess. it was past the last tip on the indexer.
2. I adjusted the settings to the following.
Dwell 30 degrees
rpm 600 rpm
timing 12 degrees.
3. I then connected the vac. hose from the carb. to the vac. advance unit. The timing and the rpm changed.
Dwell 30 degrees
rpm 900 rpm
timing > 16 degrees * way beyond the last tip on the indexer. but still visible with timing light.
Summary
.............Pre.........Post..........C onnected
Dwell......35 deg.......30 deg......30 deg
rpm........800rpm......600rpm......900 rpm
timing.....> 16..........12............> 16
............* my guess................* my guess
So, is this normal for the rpm to increase after the vac. hose is reconnected, and for the timing to increase.
thanks,
kdf1986
Here is a photo of the Bubba connection.
Small correction - althought it is correct that there is no vacuum at idle at the PORTED vacuum nipple, it is still MANIFOLD vacuum (BELOW the throttle plates) - it's just "switched" off at idle.
The car ran great last night on my test spin. I guess it should after connecting the vac. advance to a vac. source. Good acceleration, no pinging....pretty smooth.
One thing I need to get is a timing light with the advance function on it. I cant tell what my timing is past the last point on the indexer. I saw some digital timing lights with an advance function that will let you dial in the timing. For 36 degrees that is what I need.
KDF
Also, how does a slightly lumpier cam affect timing?
Mike
Mike
A lumpier cam will normally require more initial timing in order to maintain an acceptable idle quality - I usually shoot for at least 18 degrees initial, and as much as 24 with a radical cam. Total timing does not change, and should remain at 36. Also, a lumpier cam will require use of a "softer" vacuum advance control unit due to the degraded manifold vacuum.
It seems some people rev the engine to get max mechanical advance and while there also set their timing. I can see this as a no difference thing but wouldn't the same be done at idle knowing this mechanical advance value?
Seems safer and easier to set static at idle with the known mechanical value. Then just check it.
Timing light, distibutor, thottle. Somehow they found an extra hand too.
Yes, you can do as you state: If you rev the engine to see and note the total advance, you can then correct the timing at idle by the number of degrees needed to obtain the difference between the noted and the desired.
However, you actually end up reving the engine about the same number of times for either method: If you dial in 36 degrees on your timing light (desired total advance) and rev the engine to note the total, you'll end up with a brief rev, a quick turn of the distributor, and another rev or two to nail the timing at 36 total. If you just wish to measure the actual total timing, you'll end up reving the engine, turning the timing light **** to correct, reving the engine again to see if you hit it, adjusting the **** again, and giving it a final rev to verify. You'll then have to do some quick subtracton and set the timing at idle by the noted difference. Not much gained... With a little practice, you can set and nail down the total timing at elevated rpm with only 2 revs of the engine, with each rev-up lasting only a few seconds.
Thats where I got mine..but be careful with the plastic pick-up!
Yeah, I learned the hard way. Melted the darn plastic on the induction pickup. It still works, but it's contorted.
thanks for your help
V8FastCars@msn.com
