damn demon
Old Sep 7, 2005 | 09:34 PM
redc3's Avatar
redc3
Default damn demon
im using a demon carb on an air gap manifold, the vacaum port in the manifold is blocked by the carb bowls. i cant use spacer under carb because its a vette ... no clearance... the main port from the carb is for my brakes. SO I HAVE NO PCV other than valve cover breathers. does anyone think this is a bad thing? guy at my speed shop says to use a vacaum canister for my brakes. i dont understand this one yet, and im not f...ing with my brakes! anyone?
Old Sep 7, 2005 | 10:06 PM
Older Than Dirt's Avatar
Older Than Dirt
Default You need one of these.
I just ordered one today. http://www.c3sharktank.com/tech2/vacfitting/index.html
19.97 + 5.00 shipping
417-724-2118
Old Sep 7, 2005 | 10:11 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You will notice he is still using a spacer under his carb, the problem is lever on the secondary pump
You might be able to tap one of the rear runners on the Air Gap like I did on my VIc Jr, my Race Demon has no vacuum ports whatsoever
Old Sep 7, 2005 | 10:29 PM
Older Than Dirt
[QUOTE=MotorHead]You will notice he is still using a spacer under his carb, the problem is lever on the secondary pump.
Oops!, never thought about that. Oh well I'm using a spacer anyway.
Redc3, add to your list one spacer and drop base air cleaner or a drill bit and tap.......whichever you prefer.
Old Sep 7, 2005 | 10:47 PM
MotorHead's Avatar
MotorHead
Granted it is a smaller spacer. loolks like an 1/4 inch or so
Old Sep 8, 2005 | 03:00 AM
VETDRMS's Avatar
VETDRMS
I just tapped the back runner of my RPM Air-Gap with a 1/8" pipe thread tap. I also did this on the Victor Jr and it worked great.
Old Sep 8, 2005 | 06:05 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
If you look at Motorheads pic, you'll see that he "T"d the vacuum line off the hole he tapped in the intake. Does your Demon have the vacuum port in the center rear of it's base? This is where I connected my vacuum line to and then "T"d like Motorhead did on his You could also tie your PCV into the bottom of the air cleaner base as an option, some aftermarket air cleaners have a knock out for this.
Old Sep 8, 2005 | 07:39 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Edlbrock makes an adapter its for sale on summit. Its not very much.
Old Sep 8, 2005 | 09:13 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
417-724-2118
thats a sweet set up!!!!!!!
Old Sep 8, 2005 | 11:21 PM
75blackray's Avatar
75blackray
Default If you dont mind me asking
redc3, what kind of hood clearance do you have with the air gap and the demon? Right now I have a performer w/ demon and very very little hood clearance, and was thinking airgap when I changed heads.
Old Sep 9, 2005 | 08:42 AM
69396Chevy's Avatar
69396Chevy
Had the same problem after I went to a Holley. I bought a 3/8 pipe tap (which is the correct size for this hole) and tapped the hole in the intake. Pipe threads are tapered so the further down you run the tape the lower you can get the vacuum fitting in the intake. Then I put a chrome gardner wescott 90 degree fitting in it. It worked great!
Old Sep 9, 2005 | 05:14 PM
redc3's Avatar
redc3
fantastic ideas fellows! id buy all of you beer if i could. is there any problems with sharing vacaum with the brakes? do they still operate properly?
Old Sep 9, 2005 | 05:18 PM
redc3's Avatar
redc3
with a 3' k&n filter ( the one with the filtered top/not chrome ) i have zero clearance, but enough to shut my hood. if i install the allthread for the nut to high, it will make the nut scratch the underside of my hood as the engine torques back and forth. i used a self locking nut, so i wouldnt have to use a lock washer, thus taking up mor space.
To damn demon
