zz4 intake manifold
Old Sep 8, 2005 | 10:50 PM
lvjohn's Avatar
lvjohn
Default zz4 intake manifold
Having a problem with my zz4 engine. Keeps leaking from the intake manifold (passengers side rear) coolant into the oil,curious if anyone else has had this problem. Any ideas on how to prevent this from happening again.
Old Sep 8, 2005 | 11:59 PM
jackson's Avatar
jackson
Apply silicone around water ports at each end of head and around each end of both sides of intake (total of 8 water ports). Silicone the heads' water ports ... then lay the intake gaskets on ... then silicone the intake's water ports ... then install the intake.
Old Sep 9, 2005 | 08:03 AM
lvjohn's Avatar
lvjohn
Ok thanks for the reply i will try that.
To zz4 intake manifold
