454 Ready
Old Sep 10, 2005 | 03:10 PM
superdad60's Avatar
superdad60
Default 454 Ready
Dropped in a 72 454
and sweetened it up a bit inside and out
Once I figure out to get tranny back in
I'll be sitting pretty
Old Sep 10, 2005 | 03:14 PM
Empatho's Avatar
Empatho
Nice
Old Sep 10, 2005 | 03:37 PM
GDaina's Avatar
GDaina
Be careful with that deep pan...you will bottom out and scrape the pan...
Old Sep 10, 2005 | 03:55 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I have those same valve covers, they are worth $100.00 on e-bay.
What inake do you have. Looks good
Old Sep 10, 2005 | 04:36 PM
superdad60's Avatar
superdad60
Edelbrok Torqer II
Jot hot coated
Old Sep 10, 2005 | 05:40 PM
mandm1200's Avatar
mandm1200
Looking at the left side header, I don't think he's concerned abuot scratching the oil pan.
Old Sep 10, 2005 | 05:43 PM
superdad60's Avatar
superdad60
Clears the steering box.
Besides: Chicks dig scars
Old Sep 10, 2005 | 07:04 PM
Brettmc's Avatar
Brettmc
Looks good. The black engine really sets off the polished/coated pieces. What are the specs?
Brett
Old Sep 10, 2005 | 07:48 PM
fl_rider's Avatar
fl_rider
Default Nice looking engine!!!
I hope she runs as sweet as she looks!!
Have fun!!
Chris B
Old Sep 10, 2005 | 08:49 PM
rosslato's Avatar
rosslato
thats a thing of beauty, nice work
Old Sep 10, 2005 | 09:34 PM
kdf1986's Avatar
kdf1986
Gotta like those big blocks!!!
kdf 73 454
Old Sep 11, 2005 | 01:40 AM
VETDRMS's Avatar
VETDRMS
Man, that air filter makes it look like that big motor will be breathing through a coffee-straw...
Looks good!
Old Sep 11, 2005 | 08:18 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Love any BB. Not my favorite colors though.
All that dinging is why I chose stock manifolds for now. That can't help air flow and it would bother me to smash up a $1500 set of chrome Hooker side mounts.
That oil pan does look deep. Watch out is you have a lowered front end. I'm using a Moroso pan and have about 4" clearance at the pan.
Old Sep 11, 2005 | 08:29 AM
Steve's74's Avatar
Steve's74
Uh, Len, the proper headers don't require dinging. They're close, but they clear. And yes, the steering coupling will be replaced before it hits the road.
I kinda like that black paint. It sets off the aluminum and chrome differently.
Steve
Old Sep 11, 2005 | 08:51 AM
superdad60's Avatar
superdad60
Originally Posted by Brettmc
What are the specs?
Brett
1972 454 Block .030 bored and tested (2 bolt mains)
Eagle H Rods
New domed pistons
1969 Heads Reconditioned with all new valve guides and appropriate springs
Solid Lifter Comp cam 1500 - 5000(I know...I have read)
Upper and lower windage tray
High volume pump with 8" pan (only 1" deeper than stock)
Mr. Gasket Push Rods
1 piece oil pan gasket with studs and nuts
New flywheel and balancer
Pete Jackson Cam Gears (Noisy) with billet cover
New Centerforce clutch, TO and pressure plate
Crane Roller rocker arms
1 teeny weenie airfilter to fit under the hood
Old Sep 13, 2005 | 11:04 AM
Steve439's Avatar
Steve439
It looks like if you ran a stock 66-67 427 air cleaner base you'd be able to run a taller air filter.
Old Sep 13, 2005 | 11:30 AM
Brettmc's Avatar
Brettmc
Try and snag a set of solid lifters with the laserhole in the face. It greatly enhances the lubrication at the cam lobe/lifter. Comp has them, as does Crower. Should be a torque monster.
Brett
Old Sep 13, 2005 | 11:34 AM
Corey_68's Avatar
Corey_68
Eagle H Rods
New domed pistons
Like the other said be careful w/ the pan, my stock pan didn't like speed bumps. I thus switched to a Mororso w/ kickouts.
She looks great
Old Sep 13, 2005 | 01:06 PM
GDaina's Avatar
GDaina
He should be...the bottom will be caved in...ask me how I know...
To 454 Ready
