74 suspension question
Old Sep 11, 2005 | 06:21 PM
vhilts's Avatar
vhilts
Default 74 suspension question
Hello all,
Newbie to this forum and have a question. I have a 74 vert. I bought the car 9 yrs ago for a project and have since gone through the whole car, less interior and paint/body. Stock ralley wheel with new tires and the distance from the ground to the bottom of the LR fender well is 28'' but the distance to the RR fender well is 29 1/2''. I have also taken measurments at frame to ground locations and came up with the same thing. I am 1 1/2 inches higher on the RR. I restored all of the rear suspension parts. Bushings, trailing arms, brakes, etc. The spring is the stock spring but it has been bead blasted, painted, tefloned, and re-assembled. I am totally confused as to why there is this much of a difference in the side to side ride height. And I dont think there is a way to lower each side independently is there? Any help will be very much appreciated. Thanks for your time!!
Old Sep 11, 2005 | 07:45 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Check at the end of the spring where the bolt goes through. If one side is tighten more than the other this will make a difference.
Old Sep 11, 2005 | 10:47 PM
flynhi's Avatar
flynhi
If by stock spring you mean the original spring, it is now 31 years old and may be a little tired on the driver's side where most of the load has been (driver and battery).
You can adjust with the spring bolt as above, replace the entire spring, replace the main leaf or swap ends with your existing spring and adjust height with spring bolts.
If OE is not important to you, consider a composite rear spring for better ride quality.
Your 74 has rubber body mounts which may have deteriorated or even fallen out on one side.
Old Sep 12, 2005 | 02:33 PM
vettedesk's Avatar
0vettedesk
Supporting Vendor
Default Suspension Question
If you see a height difference from right to left you might want to check the Side Yokes that go into the differential. If there is more than 1/8" play than they need to be replaced, especially if you see the spring getting tired.
Vettedesk
Old Sep 12, 2005 | 05:48 PM
Mike Ward's Avatar
Mike Ward
Vettedesk
Huh? That's a new one. Can you explain how the physics works on this one please?
Old Sep 12, 2005 | 05:55 PM
big_G's Avatar
big_G
Old Sep 12, 2005 | 09:14 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Old Sep 12, 2005 | 09:24 PM
vhilts's Avatar
vhilts
The height at the ends of the spring are the same. Thanks for your reply.
Old Sep 12, 2005 | 09:27 PM
vhilts's Avatar
vhilts
I agree the stock OEM spring is 31 years old and probably needs replacing. I checked the rubber body mounts and they all look the same. So no major deterioration. One thing, When I drove the car home 9 years ago after buying it from the original owner, I took pics. I went backk and looked at them and it appears that the car was sitting right. Meaning this problem was not present then. So, I want to believe that it is something I have done in the restoration of the spring, rear end, front end, etc. Thanks for your reply!
Old Sep 12, 2005 | 09:28 PM
Van Steel's Avatar
Van Steel
Than check the rear body mounts.
Did you rebuild the front suspension at all? Maybe one of the front springs is not set correctly in the pocket
Old Sep 12, 2005 | 09:30 PM
vhilts's Avatar
vhilts
Vettedesk
The actual 3rd member is something I never touched. So the yokes are original with nothing done to them. But, I remember giving them the once over before reassembly of the half shafts. Thanks for your reply.
Old Sep 13, 2005 | 12:28 PM
Mike Ward's Avatar
Mike Ward
Pending an explanation from the poster of that comment, I would not put too much time into thinking about it.
I fail to see how a side yolk moving horizontally can cause the entire car to move vertically. It can cause the wheel to lose it's correct camber setting but that's about it.
Old Sep 13, 2005 | 05:12 PM
Van Steel's Avatar
Van Steel
Ride height is effected by front springs, rear spring and body mounts if it leans. If your mounts are fine, try the front springs.
Old Sep 13, 2005 | 08:14 PM
vhilts's Avatar
vhilts
In answer to the question someone posted about the front spring. YES, I cut one coil off of each side. But with past experience behind me, I made triple sure that the springs were both planted in the trough in the correct position on the lower a frame.
I want to say thank you to all who posted to this thread, you have helped me a great deal! Tonight, I jacked the rear of the car up and put jack stands on the frame at the same locations R and L (just fwd of the rear wheels). The car is now level as I checked it. I removed both rear wheels. On the LR trailing arm assembly, I grabbed under the brake rotor and pulled upward. I was able to move it upwards about 1'' to 2'' depending on how hard I tried. Then I did the same thing on the RR trailing arm assembly (note: this is the side that was 1.5 inches higher) and I could barley raise the assembly an inch without straining really hard. There was a huge difference in the amount of force needed to duplicate the task from the LR. There was a comment made about the original spring being 31 years old. The LR is the side that the driver, and battery are on. I think the spring is the culprit. I think my problems will be solved with a new spring. What do you guys think?
Old Sep 14, 2005 | 10:33 AM
Van Steel's Avatar
Van Steel
Check the front spring again and make sure they are seated correctly up top.
Also take a measuring tap and measure from the tip of the spring to the frame. If there is a difference from the right side to the left side, your spring is arched more on one side than the other.
Old Sep 14, 2005 | 06:58 PM
vhilts's Avatar
vhilts
I called a corvette tech/racer today and after hearing the story told me it was for sure the worn out original spring. I hope this helps others as well. Thanks for all the advice!!
To 74 suspension question
