"just making sure" carb question
Old Sep 11, 2005 | 07:14 PM
jimbow's Avatar
jimbow
Default "just making sure" carb question
I have a "81 w/computer controlled quadrajet carb. I would like to disconnect the computer but then I would have to get another carb, right? Because the mixture (rich-lean) is determined by the computer via the mixture control solenoid, right?
If this is correct, would the Eldebrock 1903 be a good replacement?
Come on! I "KNOW" you'uns have the answers! thanks in advance, jim
PS: also, I've read on another thread that when changing from an automatic trans. to a manual (which I recently did), the computer would requre a different PROM....anyone got any wonderful news here?
Old Sep 11, 2005 | 09:06 PM
CGGorman's Avatar
CGGorman
Alright, I own a '68 so my knowledge of the new cars is limited...
If you are removing the CC Carb and swapping in a manual tranny...just replace the distributor also and remove the computer altogether.
Old Sep 11, 2005 | 09:23 PM
big_G's Avatar
big_G
81=new? J/K
Old Sep 11, 2005 | 09:27 PM
page62's Avatar
page62
A new carb and distributor are called for. The Edelbrock 1903 is a very good choice...if you can find one (they've been discontinued). The computer can then go in the dumpster.
Old Sep 11, 2005 | 09:43 PM
bickel's Avatar
bickel
Default i have no great info for you but a question
what other mods have you done to the engine futre mods and how much fuel do you need?
Old Sep 11, 2005 | 10:32 PM
lars's Avatar
lars
The computer still controls torque converter lock-up and cooling fan-on temp. You'll also get a Check Engine light by disconnecting, which will fail you on your emissions testing if you have that in your area.
Old Sep 12, 2005 | 10:44 AM
jimbow's Avatar
jimbow
Thanks all for the great response! Lars, the automatic trans has been taken out w/a 4speed Muncie put in...so the converter lock-up problem is taken care of. Also, I long ago wired the electric fan up direct in my console to operate it as I want...mostly when in traffic. Because I removed the Air Cond plumbing in the engine compartment and the condenser (? in front of the radiator), the car has little heat problems.
(I can't understand anyone having AC in a sports car)
ok...if the 1903 eldebrock is not an option, what would be a good recommendation? ditto for the distributor. thanks again, jim
Old Sep 12, 2005 | 12:16 PM
CGGorman's Avatar
CGGorman
Given your apparent knack for tweaking, I'd suggest a Holley or Demon carb. with mechanical secondaries and an MSD or Crane all-electric distributor. Of course, that means you'd have to swap the intake, new filter base, maybe throttle linkage, and get a CD box to control spark...
Maybe an older Q-jet and HEI would be better! Check eBay.
Old Sep 13, 2005 | 07:03 PM
jimbow's Avatar
jimbow
Default around and around, i go
I found out today that Rochester has different numbers on the Quadjet depending on wheter it was for an automatic or a stick shift!! What a mess...since I've dropped the auto and added the manual, I really enjoy driving more,but ....as far as I can tell, I'm needing a new PROm and a rebuilt Quadjet to conform w/the manual set-up.....to optimize MPG.
NOW I know!! thanks again all, jim
Old Sep 13, 2005 | 08:07 PM
Older Than Dirt's Avatar
Older Than Dirt
Jim, JMO but if you are able to run (no emissions testing) in your state I would replace the intake, carb, and distributor.There are other choices but an edelbrock performer carb and intake are two. An HEI distributor (non computer) will work fine also. These are very simple mods to do and with some tuning will wake up that L81.
Old Sep 17, 2005 | 05:52 PM
jimbow's Avatar
jimbow
older than dirt, I like your suggestions but this is a emissions state which means for now anyway, I hve to keep the original stuff on it. including the computer quadrajet. appreciate the comeback, jim
Old Sep 17, 2005 | 08:06 PM
Sharky Guam's Avatar
Sharky Guam
That's too bad because on my dad's El Camino with the same factory setup, I simply replaced the distributor with an aftermarket Accel one and installed a cam, intake and 600 cfm vacuum secondary carb. The car runs really well now and with a little bit of jetting, I got it tuned well enough where the mixture is very close to optimum for gas mileage.
To "just making sure" carb question
