Rear wheel bearings
Old Sep 13, 2005 | 10:06 PM
kdcollins's Avatar
kdcollins
Default Rear wheel bearings
Greetings all.
I have decided to replace the rear wheel bearings on the 76, getting some funky feelings and noises at times from back there. Has anyone performed this task? Anything I should know? Special tools or tasks?
Thanks.
KC
Old Sep 13, 2005 | 10:11 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
how much mechanical work have you done?
you may be sorry you opened this can of worms.
Old Sep 13, 2005 | 10:25 PM
kdcollins's Avatar
kdcollins
A good deal of machanical experience, but never have replaced rear wheel bearings on any Vette.
Old Sep 13, 2005 | 10:29 PM
Bud640's Avatar
Bud640
Old Sep 13, 2005 | 10:34 PM
big_G's Avatar
big_G
I have several hundreds of dollars worth of set-up and r+r tools to do rear bearings. The shop manual will outline the procedure. If this is a 1 time deal for you, you might consider farming those puppies out to someone who does them on a regular basis. IMO
Old Sep 13, 2005 | 10:39 PM
72rdstr's Avatar
72rdstr
If you're not mechanically inclined and willing to invest some time, this is not a job for you. Otherwise, its pretty simple; except those damn bolts.
Old Sep 13, 2005 | 11:16 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I can rebuild your bearing assemblies (not w/t-arms) for $200 a side.
http://www.vansteel.com/index.cfm?fu...ups&Group=1000
Old Sep 13, 2005 | 11:27 PM
goinbroke's Avatar
goinbroke
These have some great pics that may help show you what is involved.....courtesy of zwede.
http://www.corvetteforum.net/c3/zwed...ailingarm1.htm
http://www.corvetteforum.net/c3/zwed...ailingarm2.htm
Old Sep 14, 2005 | 01:02 AM
TonySinclair's Avatar
TonySinclair
Whew! After reading that, sending 'em out sounds like a bargain...
Old Sep 14, 2005 | 06:26 AM
gerry72's Avatar
gerry72
The only thing harder to replace/repair for a C3 novice is the heater core. Yes, farm the job out to Van Steel. Don't try to use local resources since this is one of those things where experience makes the difference.
Old Sep 14, 2005 | 06:32 AM
Gary79's Avatar
Gary79
you can do this yourself, I did. do a search on this forum, as this has been cussed and discussed many, many times.
Old Sep 14, 2005 | 08:48 AM
jimmygmartin's Avatar
jimmygmartin
I first did this job as a kid, I had done alot of mechanical schlepping, but was inexperianced at presion work. Not as bad as people make it out to be, but I redid it 1-2 times. I would not perform the job now without investing in the specialty tools. Doing my own work is a matter of personal satisfaction. All that being said, next time I'm sending it out!
Old Sep 14, 2005 | 07:44 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
I think this is the way to go. There are instructions on Van Steel's website on how to get the assemblies off. I've heard many say unless you know what you're doing or have the time/money to make a few mistakes, it's best to farm it out.
Old Sep 14, 2005 | 08:41 PM
kdcollins's Avatar
kdcollins
I am convinced that this one should go downtown.
Thanks for all the recommendations/advice.
KC
Old Sep 15, 2005 | 08:15 PM
crazcorkath's Avatar
crazcorkath
I sent my trailing arms to vansteel to rebuild. I have heard it is a pain in the a__ to do them.
Old Sep 15, 2005 | 09:49 PM
David Ey's Avatar
David Ey
vanSteel has my business too.......they were a pleasure to deal with.
David Ey's Avatar
David Ey
Old Sep 15, 2005 | 09:58 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Cool links. Thanks for posting these. Now added to the Corvette Bookmarks.
Old Sep 15, 2005 | 10:01 PM
Eddie 70's Avatar
Eddie 70
A couple more I have bookmarked.
http://forums.corvetteforum.com/show....php?t=1041247
http://www.c3vr.com/forum/forum_post...466&PN=1&TPN=1
You may have to register to look at the bottom link.
To Rear wheel bearings
