removing center instrument bezel - 69
Old Sep 14, 2005 | 12:00 AM
colorado1967's Avatar
colorado1967
Default removing center instrument bezel - 69
I found an old bezel to cut and want to install an after market deck. I would appreciate any tips for removing instrument bezel (non-a/c) from my 69. Couple of questions:
- How to remove two nuts on bottom side under the radio? Short of removing heater controls I don't see any easy alternative.
- Do you have to remove the radio first or just the two nuts on the shafts?
Thank you all very much for the help!
Old Sep 14, 2005 | 08:04 AM
pws69's Avatar
pws69
I found it easiest to start at the back of the whole shooting match - remove the screws for the E-Brake cover and remove it, then take the shift console out and remove the tunnel, then take the gauge bezel / radio apart. The nuts you refer to are a bit of a trick... patience.
Old Sep 14, 2005 | 08:40 AM
colorado1967
Thanks PWS. My tunnel cover is also held in place by the two bottom bolts of the bezel. It looks like it will take patience.
Old Sep 14, 2005 | 10:53 AM
rponfick's Avatar
rponfick
As I recall, you don't have to remove those 2 nuts completely. Just loosen them enough to slide the console cover out. As stated, with patience, you can get to them with a small wrench from the back side. Of course, the lower side console panel covers need to be removed from both side. Good luck.
Old Sep 14, 2005 | 10:57 AM
Wrencher's Avatar
Wrencher
Default two nuts..
I found them easy (well, relatively easy) to get to simply by removing the E-brake cover, shifter cover (4 speed) and the heater controls. Mine has A/C, so yours should be even simpler than mine. At that point I use a real small end wrench to loosen them and slide the console back off of them. The console is slotted.
My biggest mistake was leaving the battery hooked up. Cost me a new amp gauge. Bad part is I do this for a living and knew better
Hans
Old Sep 14, 2005 | 11:14 AM
Red 69's Avatar
Red 69
I'd take my time and untighten the two nuts from studs directly under the radio first. Over time, other people have replaced the two identified nuts with wingnuts for easier on-off. Get these two nuts off, and you will save a lot of work and risk of breaking other parts in the console. Be careful not to stress that bezel and break that. The top is notoriously sensitive to stress and breaking. I hate that job!
Old Sep 14, 2005 | 04:15 PM
Gordonm's Avatar
Gordonm
I just took mine out last night. I loosened those two nuts and left the radio in the car. Just push it back a little and the center bezel will come forward with a little effort. Be careful though. I had mine out in about 20 minutes. Now going back in takes a lot longer!
Old Sep 14, 2005 | 05:31 PM
colorado1967
Thanks all!!
Old Sep 14, 2005 | 05:48 PM
ksbunting's Avatar
ksbunting
Just did this on my 68 coupe a few days ago. No need to remove the emergency brake console or the shift console. (The less you remove the better it is) Remove the two front console extender panels that are on each side of the radio and just reach under each side with a small wrench or 1/4 inch drive socket set to undo the nuts holding the gauge panel. Obviously it will be easier if you remove the radio first. After you remove the two nuts holding the gauges to the console, remove the screws holding the gauge panel to the left and right vinyl dashboard sections and you should be there. My car has A/C and it still was relatively easy if you go slow and don't force anything. Not sure how the windshield wiper switch and related panel is attached on a 69 but on my 68 I had to remove that as well. You can do it,,
Old Sep 15, 2005 | 07:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ksbunting
Just did this on my 68 coupe a few days ago. No need to remove the emergency brake console or the shift console. (The less you remove the better it is) Remove the two front console extender panels that are on each side of the radio and just reach under each side with a small wrench or 1/4 inch drive socket set to undo the nuts holding the gauge panel....
No need to remove the console or the e-brake console. Place a rag over the console to protect it. Take your time.
Old Sep 15, 2005 | 08:58 AM
pws69's Avatar
pws69
Well, as you can see, there are as many ways to bubba this apart as you can think of! Just be aware that you need to put it all back together and preferrably without scratching or tearing anything. The "minimalist" approaches certainly do get it out a little quicker, but I have found that reassembly can be a real pita with these methods - the more that you take out of the way, the more likely you are to NOT scratch.
That's my 2 cents.....
Old Sep 15, 2005 | 09:00 AM
Vesa's Avatar
Vesa
the same with my -73
To removing center instrument bezel - 69
