Soft Cam Lobes?
Old Sep 14, 2005 | 10:13 PM
76project's Avatar
76project
Default Soft Cam Lobes?
I have a 76 and someone told me that around that year GM used a softer metal on the cams (lobes) on a L48 engine. They wear down which causes a loss of power from not opening enough. Anyone have any info on soft cam lobes? Anyway to tell if cam lobes are wore down without complete disassembly? I realize my poor L48 engine is pretty gutless, and I will do some to correct that in the future, but need to run what I have for now.
Thanks for the help
Old Sep 14, 2005 | 10:26 PM
lars's Avatar
lars
GM did have some cam failures related to soft cams. But when the cam fails, there is no doubt that you have suffered a massive failure of some type: When the cam lobes wear down, they immediately chew up the bottom of the lifters. The chewed up lifters them shave the lobes right off the cam, making the cam lobes on the affected cylinders completely inoperative. You end up with a distinctive miss, often associated with popping out the exhaust or popping up through the carb. If your engine is running on all 8 cylinders with no irritating miss, your cam is okay.
Old Sep 14, 2005 | 11:12 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
[QUOTE=lars] You end up with a distinctive miss, often associated with popping out the exhaust or popping up through the carb.[QUOTE]
does it sound like an exhaust leak or does it sound different will the sound get louder when you reve the motor.
Old Sep 15, 2005 | 08:12 AM
Toms82's Avatar
Toms82
Default Soft cam
Hi,
You can check your cam lobes by removing the valve covers and observing the amount of lift on the rocker arms.
Hope this helps.
Tom
Old Sep 15, 2005 | 11:02 AM
Wrencher's Avatar
Wrencher
To elaborate a bit, when the cam lobe and coresponding lifter wear enough to start "going flat" it happens real fast, like within a few hundred miles, and they wear down to nothing (zero lift). The resulting performance is unmistakeable, so if your engine runs good, that is not an issue.
It was a real problem on the SB in the 70's - 80's, but I'm not sure why, and I know some folks here have had problems with some Comp Cams products.
Hans
Old Sep 15, 2005 | 08:55 PM
mandm1200's Avatar
mandm1200
I had a 76 Camero that wiped an exhaust lobe. Not too hard to troubleshoot.
Old Sep 15, 2005 | 09:33 PM
Kid Vette's Avatar
Kid Vette
I had a '67 Impala with a 283 that wiped a couple lobes. As Lars stated it started popping through the carb.
I've talked with an old engineer who used to work at GM. He stated that the cams were flame hardened in an unattended operation. I think there was a gas fired burner for each lobe. Sometimes the flames would be extinguished and it wouldn't be caught immediately. Those lobes where the flame was extinguished would be soft.
Old Sep 15, 2005 | 09:46 PM
chris75stingray's Avatar
chris75stingray
i havent had a lobe get wiped, but i did have my rocker arm completely loosen up. and you can definetely tell when one of the valves is not opening.
Old Sep 16, 2005 | 08:14 AM
not a '76's Avatar
not a '76
in my other car hobby (volvos) aftermarket cams are not treated in the same way the OE cams are. and the aftermarket cams slowly wear down over time. its because they arent hardened enough (or some other similar metal treatment). but as it turns out OE volvo cams are harder than american cams and basically never wear. and aftermarket cams are made the same way american cams are. so its probably the cam went from better than normal to what most people consider normal around your year. so dont worry about it too much.
Old Sep 16, 2005 | 08:52 AM
stingr69's Avatar
stingr69
The L-48 is pretty gutless even when all the cam lobes are still there.
I tore my '80 engine down to repair a bottom end problem and give it an overhaul. The miles were about 45K and the bores were still perfect. The cam had a lobe or two that had worn enough to be seen with the naked eye. The engine did not have any of the classic worn lobe characteristic "popping" sounds when running. In fact it ran great that way. Just something to think about.
-Mark.
To Soft Cam Lobes?
