camber adjustment
Old Sep 16, 2005 | 12:58 AM
gator79's Avatar
gator79
Default camber adjustment
I lowered my rear suspension with longer boltsand now I have too much negative camber. the adjustment cams are maxed out. is there any other way to get more adjustment other than installing adjustable lower strut rods?
Old Sep 16, 2005 | 01:44 AM
Retro78's Avatar
Retro78
Something is wrong. Are your side diff yokes worn? Also check the strut bushings...something is not correct.
Old Sep 16, 2005 | 09:36 AM
big_G's Avatar
big_G
Old Sep 16, 2005 | 02:07 PM
gator79's Avatar
gator79
I dont feel any play in the rear wheels, it was fine until I lowered the rear with 9 inch spring bolts. my rear ride height is 28 inches.
Old Sep 16, 2005 | 02:24 PM
Federot's Avatar
Federot
Upon lowering, it has been suggested to put a 1/2" aluminum plate between the rear diff and the strut rod mounting bracket. I think it was an article on vettefaq.com
You could also get lots of adjustment using heim joint adjustable strut rods.
-Fed
Old Sep 16, 2005 | 02:33 PM
redc3's Avatar
redc3
-Fed
with the heim joints, but im sure you have a saggy spring. i lowered mine with no camber problems and plenty of adjustment left
Old Sep 16, 2005 | 04:10 PM
Techno's Avatar
Techno
It will be difficult to notice a shot bearing with the 1/2 shafts still hooked up, they're part of the suspension and hold this part in place.
Old Sep 16, 2005 | 07:07 PM
gator79's Avatar
gator79
the spring is a brand new 9 leaf, that is why I lowered it. the new spring raised it 1 1/2 inches over the fiberglass stock spring.
Old Sep 17, 2005 | 09:36 PM
Federot's Avatar
Federot
Fiberglass spring isn't stock...and going from fiberglass to 9 leaf seems like a step backwards. I could be wrong but...
Old Sep 17, 2005 | 09:52 PM
gator79's Avatar
gator79
fiberglass is stock on my 81, if you ever have a fiberglass spring break in half on you while driving you will never want another one. people talk of the side differetial yokes wearing, I have not had a corvette apart but if it is set up like a standard rear axle yoke there is nothing to wear except where the seal rides on the yoke, what wears on these yokes?
Old Sep 17, 2005 | 09:59 PM
big_G's Avatar
big_G
The side yokes wear at the pinion shaft. They carry alot of load, especially if the camber is set negative, as well as some thrust loading from cornering..
Old Sep 17, 2005 | 10:08 PM
Federot's Avatar
Federot
Sorry, I looked at your forum name and made an assumption about the year
The ends of the yokes wear inside the diff. That's why they make yokes with hardened ends like: 1963-79 Remanufactured Heavy Duty Differential Side Yoke
They describe the problem as: "The stock side yoke ends wear down depositing damaging metal into the rear end. Worn yokes cause rear wheel camber problems which causes tire wear. Our retrofitted side yokes are made from original GM yokes. Once reconditioned, precision machined 0-1 tool steel button inserts are installed in the ends. The button insert itself is hardened and press fit into the yoke."
Also, strut rod bushings that are "bound up" and don't pivot as the trailing arm moves causes undue pressure on the yoke, causing this wear. So you might have to do exactly what I did...start from scratch on the rear end, replacing/repairing everything.
To camber adjustment
