Pulling the steering box
Old Sep 16, 2005 | 03:35 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Pulling the steering box
Engine is a smallblock and the headers are Hedman 68301's (with smog tubes)
When pulling the steering gearbox out, will the header need to go too? Looks like it can be unbolted just fine and lifted straight out, probably pulling the pitman arm first for simplicity.
In fact, it looks like an easier gearbox to pull than most others I've done in my long-ago years as a brake&front end man.
Car is a '76, thanks!
Old Sep 16, 2005 | 04:00 PM
norvalwilhelm's Avatar
norvalwilhelm
Yes I pulled mine without touching the headers. After removing the 3 bolts it is a smooth back and slides right out.
Old Sep 16, 2005 | 04:03 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Don't take the pitman arm off the box. Take it off at the power valve.
Old Sep 16, 2005 | 06:13 PM
SanDiegoPaul
Thanks that's what I figured by looking ... mine's leaking pretty good and needs to go.
Van Steel thanks too for clarifying this....
To Pulling the steering box
