'68 Windshield wipers/washers
Old Sep 16, 2005 | 04:34 PM
68vertible's Avatar
68vertible
Default '68 Windshield wipers/washers
I know 68 wiper arms didn't have the washer tubes, and as best I have been able to tell from the build manual, there are supposed to be squirters under the cowl vent panel. Problem is, I can't find any of these things around. I've thought about using the 69 headlight squirters that are available as repro and make a nice stainless bracket for them to mount onto the cowl vent panel screws. I've also heard that 69 wipers will not work on a 68, but that doesn't seem right since pretty much everything is the same (door, trim, windshield, etc.) so can I put 69 wipers with tubes on my 68? Will the tubes from a 69 fit on my 68 wipers? The vette is not original so I'm just looking for a good working solution that looks like it was meant to be there. I don't plan on needing them, but just in case.....
Old Sep 16, 2005 | 05:03 PM
CGGorman's Avatar
CGGorman
I was in the same boat. I decided to make a set of squirters for myself using 3/16 OD copper tubing. Took a bit of fiddling, but they work fine and cost me about $2...
Old Sep 16, 2005 | 08:53 PM
Techno's Avatar
Techno
I don't know what fits where but like CGGorman said make your own or buy one off the shelf and make it work. No reason to replace the whole arm for just a washer nozzle.
Old Sep 17, 2005 | 01:36 PM
TOM B1's Avatar
TOM B1
When I restored my 68,,, now sold,, I had the same problem till I found a pair at the car show, I used the 69 style and removed the brackets and soldered on brackets I made, worked good.
To '68 Windshield wipers/washers
