C3 Luggage Rack Position?
Old Sep 17, 2005 | 06:15 PM
Revman's Avatar
Revman
Default C3 Luggage Rack Position?
I figured this would be a great question for the all-knowing Corvette Forum. I just bought a luggage rack for my 69 coupe. Since this was originally a dealer installed option, I am not sure where best to position it. Should I just center it over the gas cap? I do want to make sure that I can store my t-tops on it. Can you guys tell me how far from the back of car your racks are mounted?
Thanks,
Revman
Old Sep 17, 2005 | 07:03 PM
Keno's 69's Avatar
Keno's 69
I just went and looked at my 69. It's 18 inches out from the back window. Good luck.
Old Sep 17, 2005 | 07:18 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Thanks,
Revman
NCRS Technical Information Manual calls for the rear of the rack to be mounted 6" from the center rear of the car. Of course the gas lid should be centered between the bars. The period racks bolt on using 6 bolts,later production incorrect, racks have 8 bolts. The T-Tops storage is usually behind the seats. I just happen to be going thru the manual earlier today!
Old Sep 17, 2005 | 11:32 PM
70 LS1's Avatar
70 LS1
I installed mine myself and used the forum as a guide. I figured since it was a dealer installed option, there was some room for some slop as I am sure the dealers didn't all install them exactly.
There are some good pics of mine here:
http://home.comcast.net/~baconjb/pictures.html
Old Sep 18, 2005 | 09:24 AM
Revman's Avatar
Revman
Thanks Guys. I think I will mount it based on the NCRS Manual and do the 6" in from the rear of the car.
Old Sep 18, 2005 | 09:25 AM
Don Rickles
2017 C3 of Year
Old Sep 18, 2005 | 10:45 AM
cal camara's Avatar
cal camara
Default Nice car
Was it difficult to put in the LS1?
cal
Old Sep 18, 2005 | 01:13 PM
70 LS1's Avatar
70 LS1
Not really, just time consuming. Don't want to hijack the thread so shoot me an email if you want some details.
baconjb@comcast.net
Old Sep 18, 2005 | 10:25 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
the luggage rack on my 72' is 22 from the back window and 3 from the edge of the duck tail. it was dealer installed at malcom conner chevrolet and i have had the car since 1974. the gas cap just clears the front of the rack when opened.
Old Sep 18, 2005 | 10:40 PM
wombvette's Avatar
wombvette
Default Rack and NCRS
I am surprised that NCRS would even list a spec. for a non factory installed accessory like a luggage rack. Any way the supplied rack in 69 was mounted totally different than the later style that you get today. It had little feet that were off to the side.
Old Sep 18, 2005 | 11:55 PM
Z-man's Avatar
Z-man
I had a dealer installed rack that looked identical to the stock ones. It was hinged at the front with quick release locks at the rear. You could raise it up to fill gas without having to remove the luggage...
To C3 Luggage Rack Position?
