Coolant all over the engine....
Old Sep 17, 2005 | 06:26 PM
more_cc's's Avatar
more_cc's
Default Coolant all over the engine....
I was driving back from Monterey at the end of a great road trip and during the last couple of miles I noticed the temp creap up to about 210 - normally it sits at 190 constant. Anyway I was close to home so I opened the windows and turned the heater on. The temperature came down and I got home. Now I checked the engine and there was very little coolant in it and a lot of marks over the engine - it seems water has been hitting the fan and then bounced off the hood onto the engine. I've filled it up and started it up again but now there's a rattle coming from the engine and coolant is leaking from somewhere around the water pump area - I turned the engine off pretty quickly when I heard the rattle.
So to cut a long story short, I've got a leak somewhere and a rattle that rises with the engine speed. Does anyone know how I should best diagnose this? There's no water in the oil and the engine seems to run okay - good pressure etc. Should I fill her back up with coolant and restart it and try and diagnose it with the engine running or is that too risky?
I've got a 1980 C3 4sp with 107,000 miles on the original engine....
Any help would be great!
Old Sep 17, 2005 | 06:36 PM
big_G's Avatar
big_G
Probably the water pump is shot. A quick test is to remove the water pump drive belt, start the engine and run for only long enough to hear if the rattle sound is there or not. Rattle gone = water pump. Not gone= G/L
Old Sep 17, 2005 | 07:07 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Sounds like a bad waterpump
Old Sep 17, 2005 | 07:32 PM
Gordonm's Avatar
Gordonm
Sounds like the water pump also.
Old Sep 17, 2005 | 07:47 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Seems like all the moneys on the pump.
To Coolant all over the engine....
