spark plug wires...?
Old Sep 18, 2005 | 09:59 AM
badboyr6's Avatar
badboyr6
Default spark plug wires...?
hey guys, i'm rebuilding my 79 vette, but i got a 77 parts car, all was dandy until i took the motor out of the car... the distributor was there with all the wires, but the wires were not connected to the sparkplugs, does anyone know which wire goes where?
Old Sep 18, 2005 | 10:06 AM
Gordonm's Avatar
Gordonm
18436572. That is the firing order. Find number one on the dist and work around from there.
Old Sep 18, 2005 | 10:44 AM
fl_rider's Avatar
fl_rider
Default Here you go...
This should help
Chris B
Old Sep 18, 2005 | 11:21 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by fl_rider
This should help
Chris B
Good job on the diagram.
Old Sep 18, 2005 | 11:41 AM
fl_rider's Avatar
fl_rider
Default Thanks!!
Glad I could help.
Have a great day!!
Chris B
Old Sep 18, 2005 | 12:58 PM
GaryS's Avatar
GaryS
This should help
Chris B
Can't give much better advice than this.
Gary
Old Sep 18, 2005 | 01:39 PM
David Ey's Avatar
David Ey
Old Sep 19, 2005 | 06:40 PM
badboyr6's Avatar
badboyr6
Thanks FL-rider
UR THE BEST!!!!
Old Sep 19, 2005 | 07:12 PM
Jay M's Avatar
Jay M
Nice picture...but mine is much different.
On mine #1 is where you have #3.
Could it be because I have tach drive distributor?
~Jay
Old Sep 19, 2005 | 07:33 PM
Z-man's Avatar
Z-man
~Jay
As long as the order around the distributor is the same, the starting position of cylinder 1 doesn't really matter. It just means that your wires probably cross around or above the distributor making it a little less tidy...
Old Sep 19, 2005 | 07:46 PM
redc3's Avatar
redc3
excellent pictures. but you can go to any auto store and buy a manual for you car for like 5$. it will give you a diagram and other info you will need
Old Sep 19, 2005 | 08:06 PM
Gordonm's Avatar
Gordonm
~Jay
The HEI dist were put in and the wires are different than the pre HEI cars. Mine is also different than this. Like was said before it really does not matter where #1 is as long as the rotor is positioned right.
Old Sep 19, 2005 | 09:25 PM
fl_rider's Avatar
fl_rider
Default Yes, you can make any one of them #1
It all depends on how you drop your distributor in.
I followed the procedure in Petersen Publications "How to Rebuild Your Smallblock Chevy"
The key thing is to observe the firing order.
Old Sep 20, 2005 | 10:35 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
, you can make #1 anywhere, if you want to line it up "right", you can unclamp the dist, and start to pull it out till you can feel the gearing clear the camshaft, then you can feel it and rotate it a "tooth" at a time to put the rotor to point to wherever you want.
stock, a HEI should have #1 point towards #1 cylinder, a points distributer I've heard typically will point to #2 - but that is just as good as where the source I got it from - which I don't remember
To spark plug wires...?
