Timing question/clarification...
Old Sep 18, 2005 | 09:07 PM
TonySinclair's Avatar
TonySinclair
Default Timing question/clarification...
Quoting from Lars timing paper in the Tech Tips section:
"Remove your distributor cap and rotor. Remove the 2 centrifugal advance springs. Install the rotor and the cap (without the springs). Disconnect the vacuum advance. Start the engine. It may kick back a little due to the advance coming in immediately without the springs. If you’re using an adjustable timing light, set the light to 36 degrees advanced. Now rev the engine just a little while observing the timing marks with the light. It shouldn’t take much rpm to peg out the advance without the springs installed. With an adjustable light set at 36 degrees, align the stock timing marks with “0” when the timing is “pegged out.” Rev the engine a little to make sure the timing will not advance any further. Shut it down. Pop the cap and rotor and re-install the springs. Put everything back together, but leave the vacuum disconnected. Start it up. For future reference, make a note of the timing setting at idle. This is your new curb idle timing spec. Now give the engine a few quick rev’s past 3,000 rpm and verify that the full timing (36 degrees) is coming in."
My question pertains to the bolded sentence. Does this mean I should turn the distributor (adjust the timing) to align the stock timing marks with "0"? I'm not clear on this...
Old Sep 18, 2005 | 09:43 PM
62fuelie's Avatar
62fuelie
What he means is, with the adjustable light set to 36*, the way you find the 36* is to set the mark on the "0" on the timing tab. If the light were set to some other number, the tab will read "0" whenever you get to that number. If you don't have a "dial back" timing light, you will have to install a timing tape on the balancer or make the appropriate marks some other way and find the 36*total advance.
Old Sep 18, 2005 | 09:46 PM
lars's Avatar
lars
Yes. You have to turn the distributor to set the timing. Timing should be set to 36.
Old Sep 18, 2005 | 09:49 PM
TonySinclair
"The Man" speaks...
Thank you.
Old Sep 19, 2005 | 09:32 AM
David Ey's Avatar
David Ey
Aaaaah, Now I know what an adjustable timing light is and it all makes sense. You can't see 36 degrees without one. (or the tape) Thanks
Old Sep 19, 2005 | 09:39 AM
lars's Avatar
lars
David -
You got it. Adjustable timing light is $69 at Sears, and it's the best investment you'll ever make in a tuning tool for your car.
To Timing question/clarification...
