Torque Questions 2 ???
Old Sep 19, 2005 | 09:56 AM
pauvil's Avatar
pauvil
Default Torque Questions 2 ???
how tight do I make my halfshafts on the wheel end?? these were tight!! and how tight do you put the differential bushing itself, just till it crushes a little??
Old Sep 19, 2005 | 05:55 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Use a torque wrench and follow the specifications in the GM service and/or overhaul manuals. If unspecified, tighten until based on the lowest specification found for that sized nut or bolt.
Old Sep 19, 2005 | 08:46 PM
C3 Stroker's Avatar
C3 Stroker
I just replaced the half shafts on my '69 with carbon fiber 3.5'' shafts.....the correct torque spec is 75 ft.-lbs. for the flange bolts. (Use locks).
Old Sep 20, 2005 | 08:03 AM
pauvil's Avatar
pauvil
Thanks, how about that rubber diff bushing?? just till it begins to crush?? or till the lock washer locks??
Old Sep 20, 2005 | 09:11 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I believe it's 65 ft/lbs
To Torque Questions 2 ???
