Carb spacer question
Old Sep 20, 2005 | 05:58 AM
Highhat's Avatar
Highhat
Default Carb spacer question
Here is my new motor in my 73 vette. 388 stroker. Has Victor Jr. 1-inch tall intake, and 1-inch 4-hole spacer. Comp cam xs290
http://i19.photobucket.com/albums/b1...2/Dscn1460.jpg
Any recommendations whether to keep, change or eliminate the spacer?
(Here' the car)
http://i19.photobucket.com/albums/b1...2/Dscn1458.jpg
Old Sep 20, 2005 | 08:11 AM
pauvil's Avatar
pauvil
I think spacers generally help you make power on the top end.
Old Sep 20, 2005 | 08:34 AM
Highhat's Avatar
Highhat
Thanks. I was wondering whether too much spacer in this case could hurt.
Old Sep 20, 2005 | 09:17 AM
Gordonm's Avatar
Gordonm
That sounds like a pretty healthy motor you have in there. Have you run it at the drags yet. Where do you run it if you do. Ever go to Atco?
Old Sep 20, 2005 | 10:29 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Keep the spacer! It usually always helps performance..
Old Sep 20, 2005 | 11:36 AM
Highhat's Avatar
Highhat
You think that is true even at a 2inch overall height? Or if so, should I try 2 inch open, rather than 4 hole?
GordonM: I havent run it yet, as I just passed the 500 mile break in. Tried it on the street though last week I will go to ATCO at the least for the 1975 and older shootout. You?
Old Sep 20, 2005 | 11:57 AM
Gordonm's Avatar
Gordonm
I have run many times at Atco. It is only about 20 minutes for me to go. I'll sometimes go on a Thursday night for the street muffled cars. If you get there when the gates open you can get in 4 or 5 runs before the crowd gets there. When is the 75 and older shootout?
Old Sep 20, 2005 | 12:03 PM
Highhat's Avatar
Highhat
I think it's this:
Sun Oct 2 8am Philadelphia Modifiers Old Time Drags Show Swap Meet
Old Sep 20, 2005 | 12:30 PM
BigBlockk's Avatar
BigBlockk
(Here' the car)
The larger the spacer you have the more accelerator pump shot you need.
BigBlockk
Later.....
Old Sep 20, 2005 | 12:38 PM
Highhat's Avatar
Highhat
Do you know if simply a larger shooter would work, or wou ld I have to put in a larger pump? I have a Holley HP with standard 35 shooters on primary and secondary
BigBlockk
Later.....
Old Sep 20, 2005 | 01:18 PM
GrandSportC3
In most cases, a 1 inch open spacer works better than a 2 inch spacer..
The best spacer available is the HVH Super Sucker which combines the advantages of open and 4-hole spacers.. That's what I'm using!
Old Sep 20, 2005 | 01:20 PM
Highhat's Avatar
Highhat
That is the one that where the holes widen at the bottom?
Old Sep 21, 2005 | 10:23 AM
jimvette999's Avatar
jimvette999
Nice engine and car Highhat
Jim
Old Sep 21, 2005 | 10:26 AM
GrandSportC3
That's the one
Vetdrms also used that spacer and had good success with it.. I believe that he used the 2 inch version..
Old Sep 21, 2005 | 12:54 PM
BigBlockk's Avatar
BigBlockk
Plenum volume dictates how much accelerator pump shot you need. When you add a spacer you are adding plenum volume thus you need a larger volume of fuel. You can probably tune the pump to get more fuel volume. I bout they are setup to deliver 100% out of the box.
Add the spacer and see if it gives you any trouble. The pump circuit is probably a little rich anyway so adding the spacer may make it just right. My earlier post was simply to warn you of a problem. If you install the spacer and get a stumble out of the motor this is the fix.
By the way, a larger shooter won't increase fuel volume. It simply delivers what fuel volume there is faster.
BigBlockk
Later.....
To Carb spacer question
