I've heard that all C3 engines have 4 bolt mains. I have a '68 327-300 I intend to start building but want to make certain I'm not putting more stress on the mains than is appropriate. Instead of dropping the pan to find out, can anyone tell me if I will find 4 bolts?
Okay...I'm editing this post to get an opinion from the group. Starting with a 327-300 that is essentially bone stock, does it make sense to try and build a ZZ4 clone using ZZ4 heads/intake, similar grind roller cam and roller rockers? A build like this will cost a minimum of $2500. But I don't know how much the shorter stroke will affect compression ratio. I had not planned on doing any major changes to the short block other than line bore, new bearings/rings and polished journals. Am I throwing too much $$$ into this build or should I bag the original 327 and leave it alone and just drop in a crate? Thoughts????
I believe you have 2 bolt mains....didn't have 4 'till 1970 with the LT-1 350-370. BTW, 2 bolt mains are ok, especially if you switch to ARP studs, good for maybe 500 crankshaft hp.
No way I'm going to get 500 crank HP out of my build so I'll go with what I have and use the ARP studs.
The 327 motors never came from the factory with 4 bolt mains. There were plenty made from a 350 block that a 327 crank was laid into. There were 4 bolt mains before 70. 69 saw the first 4 bolt mains in the 302 and the 350 motors.
Are the mains really the weak point in an engine? I will admit I haven't see alot of blown motors in my limited experience but the ones I have seen certainly haven't been from teh maincaps giving way?
We had a matching numbers 67 327-350 come in last year with low oil pressure. The block was cracked at each of the middle 3 crank saddles. My machinist says that can happen from excessive detonation, or high rpm with an out-of balance engine.
It depends on many factors, like what are you looking to do?? I ran my 327 for 2 seasons at the drag, every weekend at 6800rpm with slicks in a 3200lb. car. It was a balanced motor. Ripped it down and had everything checked, nothing moved. Yes mains will go, but so can anything for that matter. I've seen cranks break, rods come apart. If it's done right in the first place you'll be OK.
all these mods and youre scared to drop the pan????
I would have to jack it up, drain brand new oil, break the gasket seal, drop the pan, etc. just to find out the answer to a question that I had hoped someone on this forum could provide in 5 minutes based on their immediate knowledge. I've been working on SBC's for 36 years so no...I'm not scared to drop the pan....just didn't seem like the most efficient use of my time and the knowledge available on this forum.
The only thing I heard came in all vette engines were uncracked cranks. The story goes they would rap them when hanging and the thuds went into bread and butter chevys and rings went into vettes.
From: San Diego - Deep Within The State of CONFUSION!
Ya know, a good, solid-lifter cam and better heads would make that 327 mouse roar. Years ago, I had a 13 second '56 Bel Air two door, using that setup. I had a Muncie 4-speed and 4:56 Posi rear end. It had cheap Mr. Gasket headers and a 780 Holly single pumper ... but also 12:1 compression.
I'd win races and people would be thumping on the hood and doors, looking for glass body panels. That thing was all stock bodied and very, VERY fast for what it was. My shift points were 8500 RPM hence the solid lifters and very low gears.
There's no reason that a motor like that couldn't be built out of what you already have now, and make that Vette haul A$$ if that is what you want. You would be more pleased than using a ZZ block in my opine.
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I've found that if bearing saddles-caps need line bore, the journals will probably need more than polishing ... but, if the bearings look ok other than normal wear, and the bearing wear pattern is uniform, then you probably won't need a line bore & polish may be sufficient. If 327 is numbers matching/original-to-car, I'd suggest bagging it and either finding a core 350 or 400 to build ... or a crate.
I've got my numbers-matching original L-48 350ci motor pulled out of my '71 right now with the pan off and on an engine stand, and I can assure you that it has a 2-bolt main...sorry.
