Speedometer too slow - gear ?
Old Sep 20, 2005 | 03:15 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default Speedometer too slow - gear ?
My speedometer shows about 10mph - 12 mph too slow. From what I can tell, I need to find a drive gear that has 2 LESS teeth? Does that sound right? I plan on jacking the car up this weekend to pull out the existing gear to have a look to see how many/what color it is.
Old Sep 20, 2005 | 03:42 PM
Fevre's Avatar
Fevre
Seems there was something in the ZIP catalog that stated each tooth is worth 4.5 mph so you are on the right track.
Old Sep 20, 2005 | 07:01 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
You didn't changed tire size lately..? A taller tire will through off your speedo also.
Old Sep 20, 2005 | 09:54 PM
ruby76's Avatar
ruby76
I haven't since I bought it a year and half ago. It has 255 60 15s. I think they are slightly taller than stock, but still, the speedo is fast by 10 or so mph. And if/when I replace the tires, I'll stick with this size as I like em.
Old Sep 21, 2005 | 12:51 AM
Star79's Avatar
Star79
Color chart from transmissioncenter.net
Here's a nifty calculator to check/see what gears you need:
http://www.bgsoflex.com/speedo1.html
Old Sep 21, 2005 | 06:34 AM
tigers123's Avatar
tigers123
Default this will help
http://chevelleengineer.home.comcast.net/speedo.htm
Old Sep 21, 2005 | 06:43 AM
carl a's Avatar
carl a
i found out in a th-400 every tooth is roughly 3 to 4 mph,,,,i ran down the highway with a friend in a c-4 and he held 60 and we had push to talk nextal radios,,,i added the new gear and got it as close as possible,then dumped the th-400 for the 700-r-4
To Speedometer too slow - gear ?
