1980 L48 tach problem
Old Sep 20, 2005 | 05:59 PM
blackhammer's Avatar
blackhammer
1st Gear
Default 1980 L48 tach problem
Hi there,
been lurking for awhile around here. nice crew. Figured I would post this because I can't seem to figure it out.
I have no reading from the tach. It just sits at zero. I looked at the schematic in the shop manual, but nothing really to guide me. Where does the tach receive the reading?
Any help what so ever would be greatly appreciated.
Michael
Old Sep 21, 2005 | 12:42 AM
Star79's Avatar
Star79
Lots of threads here on tach fixing, here's the most recent with some good info on the workings/parts/etc of electric tachs
http://forums.corvetteforum.com/show....php?t=1167061
Old Sep 21, 2005 | 08:42 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Make sure the tach wire is pluged in at the distributor.
Old Sep 21, 2005 | 09:47 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Welcome to the insanity!
You can also check the tach filter which should be inline between the distributor and the tach. Usually located at the rear of the intake manifold, drivers side. It's a round metal can, similar in appearance to a typical noise filter cap, with a wire at each end. You can try bypassing it to see if the tach starts working again. If so don't leave it like this as you could damage the tach board w/electrical spikes if it's not in place. If you need a replacement, don't need it to be original and are handy with a soldering iron, I can provide a schematic of the 4 parts (two resistors, two caps) needed to construct one. Just let me know.
Now all that said, it is just as likely, if not more so, that the circuit board on the back of the tach could be bad too. Troubleshooting this is more of a eliminate everything else and if it still doesn't work, then purchase a new board and replace it.
Of course the first thing you should probably do is make sure all your wires/connections are in place, are hooked up and, have continuity. Should go from the tach output on the distributor, to the tach filter, thru the firewall to the tach board.
Hope this helps. Don't hesitate to ask any other questions if necessary.
Good Luck!
Old Sep 21, 2005 | 11:05 AM
G dad's Avatar
G dad
I could sure use the schmatics for that tach filter as my 79 did not have one when I bpught the car. Thanks. my e mail bpischlar@ctv.ca
Old Sep 21, 2005 | 09:27 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
This guy did one hell of a job posting good info. It's on an '80, but I'm sure that most will help you on your '79...
Click here...
Old Sep 22, 2005 | 07:21 AM
G dad's Avatar
G dad
Click here...
Thanks this should be helpful.
Old Sep 22, 2005 | 09:36 AM
ACECO's Avatar
ACECO
Just in case anyone needs a copy, I'm posting the tach filter schematic here for reference. I'll be away most of the weekend at the NJ leg of the Tuning for Beer tour and probably won't be checking the forum until at least sunday.
Hope this helps someone.
Old Sep 23, 2005 | 07:03 AM
G dad's Avatar
G dad
Built it yesterday works great cost me a $1 wow! that is a $30 savings over the cost of a manufactured one from Ecklers.
Old Sep 23, 2005 | 04:42 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
outstanding info!
To 1980 L48 tach problem
