ls4,ls5,ls6
Old Sep 21, 2005 | 07:26 AM
dood53's Avatar
dood53
1st Gear
Default ls4,ls5,ls6
hi ever one i have a 74 vette big block (manual) i understand that this engine is a ls4 270 hp my question is why the big deffrence in hp between my engine and ls5 and the ls6 .
is this due to the cams valves or what and what can i do to make my engine more like the ls5 and 6
Old Sep 21, 2005 | 07:51 AM
Alexarz's Avatar
Alexarz
Everything is different, from the crank to the cam, heads, pistons, rod bolts, etc. when compared to an LS6. On the other hand, the LS5 is also an oval port motor so I would think that upgrade would be feasible for you. I am not knowledgeable of the difference between these 2 motors but I am between the LS6 and those below it in regards to performance. Chevrolet used to sell LS6 crate motors and I was lucky enough to buy one. If that were still the case, you could have just bought one in the crate and swapped it out, saving your LS4 for originality in the process.
Old Sep 21, 2005 | 08:52 AM
zwede's Avatar
zwede
The difference is not as much as you'd think. 1971 was the first year for the new SAE NET power rating. Before 1971 power was rated to a standard that enabled some "creative" measurements. The '71 LS-5 was 365 hp SAE Gross and 275 hp SAE NET. So your Ls-4 is only 5 hp less than a LS-5! I forget the LS-6 SAE NET rating it was in the low 300.
Old Sep 21, 2005 | 09:41 AM
knoxboys's Avatar
knoxboys
zwede
I went to you link and was fascinated as I am headed down the same path you went down. I think You could really shed some light on where I'm going.
I don't want to hi-jack this thread so I will send you an e-mail. Hope that's o.k.
Funny when I came back in the link on your post was gone??
I'm still trying to figure this thing out.
Old Sep 21, 2005 | 10:21 AM
zwede's Avatar
zwede
Knoxboys: You can control the display of signatures. Click "user cp", "edit options" and then you should see a check box for "show signatures".
Old Sep 21, 2005 | 10:31 AM
mstanton's Avatar
mstanton
71: LS-6 325hp net, 425 gross. LS-5 285 net, 365 gross.
Old Sep 21, 2005 | 10:41 AM
Kryptonite's Avatar
Kryptonite
Default 72 Ls5
wHAT ARE THE SPECS
Old Sep 21, 2005 | 12:11 PM
BigBlockk's Avatar
BigBlockk
The '70 LS5 had 10.25/1 compression. In '71 that was dropped to 8.25/1 if I remember correctly and it became the LS4. The '71 LS6 had 9/1 compression.
BigBlockk
Later.....
Old Sep 21, 2005 | 01:19 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
270 hp 390 lb-ft (net)
Old Sep 21, 2005 | 02:28 PM
RatRacer's Avatar
RatRacer
BigBlockk
Later.....
The '71 was still called the LS-5. The CR reduction came from the use of open chamber heads that actually flowed better than previous closed chamber oval port heads. The heads were the only thing changed between the '70 LS-5 and the '71 LS-5. When rebuilding my '71 454, I used OEM '71 LS-6 pistons and they gave me approx. 9.5:1 CR. with the 110cc chamber of the '71 oval port head.
Old Sep 22, 2005 | 12:26 AM
Kryptonite's Avatar
Kryptonite
I want to go more at hole shot will a 3/4 cam do it? can I use my springs. I have good heads I know it I can feel what it wants to do, I refuse to change the intake and the carb, I have had a SB OK A FORD that was faster than KRYPT and krypt weghhs a 1000lbs less and she crawls. Tell ME what I need Everyone says its a CAM.
To ls4,ls5,ls6
