How hard is it to replace the main fuel lines (supply and return)from the tank to the pump. Mine are pretty rusty. I am dropping the tank for some clean up so now would be a good time to try to replace them. I think I read a thread a while back about using rubber in place of the steel lines? I am more worried about reliability than originality.
It's not that hard with the proper tools. (tube bender, etc). But do not run a rubber gas line, it will wear through in short order, where it rubs along the frame. Do it right or have it done, use steel. My 0.2
I recently removed my original lines. While not the hardest thing I've ever done on the car, it was a pain. The bolts on mine were somewhat hidden between the body and frame and they were pretty stuck. I ended up cutting the lines in several places and removing the pieces.
I re-installed "rubber" lines - with stainless steel woven sleeves. They won't be wearing out anytime soon...
Where did you get the rubber lines with stainless steel sleeves? That sounds like the best of both worlds.
THe hardest part is routing the larger line up the frame kickup. Many people cut the line there and use a union above the rear tire. If you are using a carburetor, a standard union is OK. If you are using fuel injection, use steel-line hydraulic unions that are made for pressure.
Jegs has them also and so do some local shops. There's a couple around here. The brand I used is Aeroquip. These lines are the same type used in the aircraft industry and many of the lines are rated from 1,500 - 2,000 psi! I managed to squeeze -8AN lines in the stock locations. (The wire in the photo goes to my fuel pump relay.)
I'm installing a -12 sized line on my frame, thinking about using stainless w/ -12 weld bungs...I'm not too fond of the idea of having an aluminium linew/ those sleeve nuts.
What about the rubber rotting? Just because its clothed in SS don't mean the rubbers going to last any longer.
Actually, the lining has teflon, braided nylon, etc., etc. in addition to something that looks like rubber. It's very strong and a bitch to cut...It's probably much stronger than the flexible section of your brake lines. When was the last time you had one of those break?? I check stuff like this frequently anyway.
How much does this stuff cost per foot?
I've only seen Teflon anything as quite high and with SS jacketing, real jacketing and not a woven chinese finger puzzle slipped on waaaaay too high.
I consider fuel injection hose to be expensive and the fuel line for my boat isn't all that cheap. It has to be changed to be dependable.
I had heard from a few folks that it could be done pretty easily by removing the body mount bolts on the right side and raising the boy 3"-4" off the frame. Unfortunately when I went to remove my body bolts I found that my #2, 3 and 4 body mounts on both sides were shot. (De-nile ain't just a river in Egypt!) This led to an 18 month frame off and I used stainless lines when we put it back together.
Has anyone else tried this method, of raising one side off the frame to install them?
I think it's roughly $7 per foot for the good stainless woven stuff, probably half for some second quality hose. I used the Aeroquip socketless hose for my return line.
