High speed blower problem
Old Sep 22, 2005 | 06:48 PM
gail's red 78's Avatar
gail's red 78
5th Gear
Default High speed blower problem
My A/C on my 78 will not blow on high speed. When you switch the blower to the high position, it blows on high for about 1-second then stops. I have already replaced the blower relay on the firewall. And I know that the relay coils that are down inside the A/C case also controls that, but they all look good. Any suggestons ?
Old Sep 23, 2005 | 12:26 AM
71SoCal's Avatar
71SoCal
My first suggestion would have been the relay, but you already got to that one.
I'm guessing that either it's the blower control switch in the console, or possibly the new relay is weak and failing. A voltmeter would quickly solve this puzzle.
BTW: Those resistor coils don't have anything to do with the high speed blower. They only operate on the lower settings to reduce voltage to the blower.
Good luck...
Old Sep 23, 2005 | 12:29 AM
carl a's Avatar
carl a
look for a fuse for the high speed ,mines behind the washer bottle ,,drivers side
Old Sep 23, 2005 | 12:46 AM
WhichVette?'s Avatar
WhichVette?
Also, check the relay connections. Mine had a bad ground.
Old Sep 23, 2005 | 07:25 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Sounds like it may be the switch it self... wiggle it a bit see if the fan motor starts up again...that's just aquick test. who knows it might be it.
Old Sep 23, 2005 | 01:16 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
When I bought my 73 Bubba had replaced the inline high blower fuse with a circuit breaker. Could be that another Bubba did the same to yours and the breaker is going bad, or they installed one with a lower amp rating.
The high blower get power from the horn relay (driver's side fender) a heavy gauge wire (orange on the 73) runs from the horn relay back across the firewall directly to the high blower relay. There should be a inline fuse in that wire near the master cylinder.
To High speed blower problem
