Torque or Horsepower?
385 sbc
Torque is the thing that turns the tires(a measure of how much force is being applied). Horsepower is the thing that says how fast you can change the rate of accelleration(a mathematical calculation of work done over time).
You can't exactly separate the two in discussion since they're not mutually exclusive when it comes to internal combustion engines and cars.
There are no right or wrong answers on this type of question. You'll get a lot of opinion and that's fine. But in the Grand Scheme of Things, it doesn't matter except in the scientific and engineering realms.
Torque is the ability to do work.
HP is the ability to get work done
Torque is the ability to pull the revs to the redline.
H.P is the level of performance (or what's happening) when it gets there!
HP = Torque x RPM / 5252 therefore at 5252 the torque will equal HP. I expect that after 5000 RPM your engine is getting into a harmonic state where the pressure waves of the compressions are building on each other and creating a tuned state that you can feel. Sounds like a great race engine.
Torque is what busts you through it, horsepower is how far you bust through it afterwards.
The above was told to me by an old 60's drag racer.
I think I'll be satisfied with a chassis dyno.
Power is just torque x RPM.
You can use a constant to convert the ft-Lbs-RPM's to HP.
Not that this is usefull for much of anything.
The question asked is kind of like "do you walk to school or carry your lunch"?
By definition, "Torque" does not move, it is static.
Think about this way, If you hang a 10 LB weight on the end of a 10 ft long stick and hold the stick out paralell to the ground without moving, you will feel the torque of 100 Ft-Lbs trying to rotate your hand. This is not power yet.
Once you start things moving, you are making "power".
Clear as peanut butter, right?
If this is the case your cam is too big for the gears in the rear.
Horse Power is the rate of doing work
If two engine have equal torque and one is at 3000rpm and the other at 6000rpm, the one at 6000rpm will have twice the horsepower. In other words it will be doing twice as much work. If someone swings a hand sledge to break rocks while another person using the same force to break rocks but is swinging twice as fast, its quite obvious who will finsh his rock pile first. The more times the same forced is applied the more work(horsepower) is done.
What gears are in that thing that it breaks loose at 5000rpms+ in 3rd gear?
Vs.
-Mark.
horsepower is then the abiltiy to use torque in order to cause motion. gears allow you to manipulate this. but evnetually the counter forces of friction and air resistance will overcome your torque.
a high horsepower engine means you can maintain a torque value for a long time (high rpm). you shift gears to lower rpm; if you have enough torque to move the new gear (mechanical advantange) and overcome air resistanc, you will still accelerate. if not, you are done.
I got 3 pulls for $60 last Saturday...very useful info. to be gotten.
