Front Sway Bar Question
Old Sep 26, 2005 | 06:19 PM
davidm_comp's Avatar
davidm_comp
Default Front Sway Bar Question
Just noticed that my front sway bar bolts are loose, was wondering if they are supposed to be this way, or if they are supposed to be tight.
Old Sep 26, 2005 | 06:29 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I have more thread showing than what you have. Also my bolt comes in from the bottom, course maybe they did your year different than my '72.
Old Sep 26, 2005 | 09:15 PM
big_G's Avatar
big_G
Tighten them 'till you have a little bulge on each bushing...with the weight of the vehicle on the tires..
Old Sep 26, 2005 | 10:37 PM
Mark PittPayne's Avatar
Mark PittPayne
Those are too loose
Old Sep 26, 2005 | 11:22 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Those look like poly bushings to me in which case they won't bulge much if at all. There should be a bit of preload on them though just to keep things tight.
-Chris
Old Sep 26, 2005 | 11:40 PM
davidm_comp
Thanks for the info, will tighten them tonight and if the weather cooperates I will drive it tomorrow and see how much of a difference there is.
Old Sep 27, 2005 | 12:55 PM
davidm_comp
Tightend up the sway bar, and much more of a solid feel going into corners, thanks again for your quick responses.
David
Old Sep 27, 2005 | 01:08 PM
Twin_Turbo's Avatar
Twin_Turbo
is your car lowered in the front (springs cut)?? I ask this because it looks like it's frequently riding on the bump stop...look at the recepticle dish next to the spring pocket, you can see where it contacts the frame. If it only does it on very hard bumps it may be time for some new shocks.
Old Sep 27, 2005 | 02:48 PM
davidm_comp
I have had the car for 6 months now, and I am not sure if the front springs were cut by previous owner. I see the marks on spring pocket where the bump stop is hitting. I think you are right, it might be happening when I go down my driveway (which is very long and quite bumpy). If new shocks are what the doctor recommends, is there a specific brand, firmness, oor length that I should look for.
Old Sep 27, 2005 | 02:54 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Bilstein shocks are the way to go. You can find them on sale for around $250/set.
Old Sep 27, 2005 | 04:26 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Just make sure they are the Sports and not the HD's.
Old Sep 27, 2005 | 05:36 PM
flynhi's Avatar
flynhi
Here are the compressiopn and rebound numbers for Bilsteins measured at .5m/sec
B36-0946 HD Front 1018N-M/Sec
1991
B46-0956 Rear 970
1580
B36-0222 Sport Front 1585
2870
B46-0232 Sport Rear 995
2795
I ran Sports for a while and I found them pretty stiff.
Old Sep 27, 2005 | 06:58 PM
davidm_comp
Ok, sounds like new shocks are on the list of things for winter projects.
Thanks Again,
David
Old Sep 27, 2005 | 11:25 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
As far as I know mine are HDs - they're great
To Front Sway Bar Question
