paint question 73 plastic bumper
Old Sep 29, 2005 | 02:50 AM
bigdave73's Avatar
bigdave73
5th Gear
Default paint question 73 plastic bumper
Ok...... I Have Painted My Bumper Twice Now And Each Time The Paint Cracks. I've Used Flex Primer Andthe Color Coat Still Cracks. I Need To Know If You Have Any Hints To This Madness Or Should I Just Pay Someone To Do It....
Old Sep 29, 2005 | 08:32 AM
vettfixr's Avatar
vettfixr
You state that you use a flex primer but you also say the color coat cracks. I believe you need a flex additive in the color coat.
Old Sep 29, 2005 | 09:14 AM
big_G's Avatar
big_G
You didn't say if the bumper cover was new. If it is old, the cracks may be in the cover itself, and showing up through the paint. If a new cover, cracks shouldn't appear even if no flex added in the color coat.
Old Sep 29, 2005 | 12:13 PM
bigdave73's Avatar
bigdave73
5th Gear
bumper was new not sure if the cracking was caused by wetsanding too soon or what. Soooo do I need a flex color coat will normal paint work. I should mention that it cracked before I could clear coat it. No point now until I do it over
Old Sep 29, 2005 | 12:29 PM
big_G's Avatar
big_G
You need to wet-sand thru the crack, removing any traces or the split paint. Re-seal and shoot color with the appropriate amount of flex additive. We don't add flex to the clear, as urethane clears are fairly flexable when cured.
Old Sep 29, 2005 | 07:36 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
i painted mine with no flex againt and no cracking.
To paint question 73 plastic bumper
