Need Tech help on HB pulley
Old Sep 29, 2005 | 08:38 AM
HunterPayne's Avatar
HunterPayne
Default Need Tech help on HB pulley
I have a 71 350 base motor (270hp), no air, 4 speed, and power steering. I have having a really hard time trying to find the correct harmonic balancer pulley set up. Is it the singel pulley with the add-on pulley for power steering or a double pulley. If it is a double pulley, then which one? This is driving me crazy.
Old Sep 29, 2005 | 10:10 AM
Tom454's Avatar
Tom454
This would be my guess...
http://www.corvette-paragon.com/cata...3-2202839532C7
Old Sep 29, 2005 | 11:02 AM
Z-man's Avatar
Z-man
I had the same setup as you for 1970. My pulley setup was a single pulley (like Tom linked to) set within a double pulley. The single pulley (farthest from the HB) runs the power steering, the double pulleys run the water pump, alternator and AIR smog pump (if you still have that).
To Need Tech help on HB pulley
