Any difference between Small Block and Big Block rear ends?
Old Oct 1, 2005 | 07:34 PM
Corey_68's Avatar
Corey_68
Default Any difference between Small Block and Big Block rear ends?
I know the SB U-joints has straps and the BB had caps but does the rear end itself differ between the two?
Old Oct 1, 2005 | 07:55 PM
GTR1999's Avatar
GTR1999
The internals were a little different between the years but I don't know of anything other then the yokes being different between SB auto/BB and SB 4 speeds?
If you're buying a used one look it over very closely. If you're building yours then you'll want 10-17 spider gears,maybe heat treated, solid steel clutches, and some other mods to build a nice street diff.
Gary
Old Oct 2, 2005 | 11:14 AM
Solid LT1's Avatar
Solid LT1
Small Block LT-1s had cap yokes too! Maybe you can take the hint GM was trying to give you when you do your rear end.
To Any difference between Small Block and Big Block rear ends?
